Good call. I have seen many aftermarket SXS arms what come bent the other way to allow for extra clearance. I assumed it would be okay if braced properly but you are right, I think it’ll be a higher stress point than if the arm was straight.
However, I put a bend in it to allow for CV clearance at full droop. If you look at the full droop CAD photo above, the CV joint would contact the lower control arm without the bend. An alternative is to have a straight control arm with a large cut out between the two lower arm heims to allow for clearance with the CV.
Thanks!!
Thread: R1 Single Seat Mini Build!
Results 411 to 411 of 411
04-09-2021 10:18 PM
Single Seat mini buggy build Ideas
By Linden318 in forum FrameReplies: 0Last Post: 03-02-2016, 01:08 AM -
pros sand mini single seat
By swampthing in forum For SaleReplies: 11Last Post: 07-04-2015, 04:24 PM -
CBR 600Fi Single Seat Build
By Blackman0809 in forum Projects in ProgressReplies: 18Last Post: 11-25-2012, 05:55 PM -
New Mini Buggy - Single Seat
By Trell1245 in forum Show off your toys in here!Replies: 21Last Post: 04-05-2011, 07:07 PM -
Terrell Extremes - single seat mini buggy build
By terrellracing in forum Projects in ProgressReplies: 22Last Post: 12-03-2010, 11:02 AM
