Page 41 of 42 FirstFirst ... 31 39 40 41 42 LastLast
Results 401 to 410 of 411
    Re: R1 Single Seat Mini Build!
    Senior Member Linden318's Avatar
    Jun 2015
    Alberta, Canada
    Calipers don’t care what side they are on. They strictly work around the axle and the torque produced by the clamping forces.
    just keep it tits up (brake bleeder tits).
    Okay that makes sense, will do! Thanks for the typical morning reply K-Fab! R1 Single Seat Mini Build!
    Jun 2015
    Alberta, Canada
    Spring is here and it’s finally warm enough outside to do some work on my buggy. I’ve started out with some CAD (computer and cardboard) to redesign my rear suspension. My original design was a parallel a arm set up which resulted in no camber change as the suspension cycled. I also needed to re-build the rear uprights to accommodate brake callipers (over looked this when I built the original rear suspension about 5 years ago) so I figured I would re do it all (uprights and control arms).
    I am going to stick with the ‘non plunging’ cvs I currently have so I have been paying close attention to keeping the axle plunge close to zero with the new design.
    Here is a Solidworks assembly of the new rear suspension. Boxed control arms (not boxed in on the computer model yet) and a new upright.
    Cardboard mock up of the rear upright and caliper mount.
    Jun 2015
    Alberta, Canada
    Final check of my numbers for my new rear suspension before I start cutting steel. Let me know if anyone has any comments!
    Camber curve (negative values):
    Full bump: 5.1*
    Ride: 1.8*
    Droop: 2.1*
    This set up will be the same width as the original suspension, 15” of travel, 4.5” frame clearance at full bump.
    Axle plunge according to the CAD is 0.1” overall change from full droop to bump. I am aware this will probably be slightly higher in the rear set up but I can live with about 0.1-0.25” or so.
    That looks like nice articulation and camber changes.
    Looks to combat scrub well.
    Jun 2015
    Alberta, Canada
    Thank you K-Fab. I think it came out well also.
    Wheel scrub is not perfect but will definitely be lower than the original design with parallel arms. Suspension design is full of trade offs/compromises R1 Single Seat Mini Build!
    Quote Originally Posted by Linden318 View Post
    Aren't they all? I don't think there's any that are just "perfect".
    I can't imagine what the F1 guys chase. 2" of travel and an absolutely incredible amount of input to control.
    Jun 2015
    Alberta, Canada
    I assume “perfect” is most likely not a word used in suspension design! Lol
    No doubt. Those guys must go in circles all day long chasing the proper numbers.
    Ah... Formula 1. That there deserves is own thread. I'm a huge fan.
    HARD WORK PAY$
    Quote Originally Posted by 67StingrayJ View Post
    Check out the very first forum on the home page - Minibuggy.net Lounge.
    There’s a long running F1 thread there.
    Supercross/Motocross also.
    No stick & ball...
    is there a reason for the bend in the lower arm? I am in the mind set that if it has a bend started is will dent to bend there easier than if it was straight, looks really good.
  1. Single Seat mini buggy build Ideas
    By Linden318 in forum Frame
    Last Post: 03-02-2016, 01:08 AM
  2. pros sand mini single seat
    By swampthing in forum For Sale
    Last Post: 07-04-2015, 04:24 PM
  3. CBR 600Fi Single Seat Build
    By Blackman0809 in forum Projects in Progress
    Last Post: 11-25-2012, 05:55 PM
  4. New Mini Buggy - Single Seat
    By Trell1245 in forum Show off your toys in here!
    Last Post: 04-05-2011, 07:07 PM
  5. Terrell Extremes - single seat mini buggy build
    Last Post: 12-03-2010, 11:02 AM
