Page 40 of 40 FirstFirst ... 30 38 39 40
Results 391 to 398 of 398
    Re: R1 Single Seat Mini Build!
    Yep that looks like it.
    Here are some pics of it measuring the ends. I also took a pic of it on the throttle body cam. The threaded end is M8x1.25 but it just attaches up there by the cam. It is probably a little loose but I think it will work on my gsxr750 motor.
    Senior Member Linden318's Avatar
    Jun 2015
    Alberta, Canada
    Perfect! Thanks for the photos. That looks good.
    I think it will work for my motor also. If not, Iíll try to make it work! I see you have just 1 cable hooked up. Do you plan to run 2 cables to pull your throttle body closed or what is your plan there?
    I only bought one cable to try it out and make sure it would work. I plan on getting another to pull the throttle closed. I also think I'll try to use them for shift cables if I can get this one to work for that too.
    We'll see.
    Jun 2015
    Alberta, Canada
    R1 Single Seat Buggy First Test Drive:
    Iím guilty, I posted my videos to the Facebook page and forgot to upload a video to the forum! Well, here it is. I put together a few clips from riding my buggy this fall. I am stoked to get it up and running and canít wait to do more testing. It is put away for the winter now, considering I donít have a heated space to work in it in the winter. I have big plans to Ďfinishí this thing up in the next few yearsR1 Single Seat Mini Build!
    Iím very pleased with how it has turned out so far. I canít thank the members of this forum enough for all the help!
    Looks great, but now I'm jealous because I'm not that close to getting mine moving on it's own power. I guess I'm still on par with the timeline though as I'm not 4 years in yet and still have some driveline work to do. Great job, but too bad you have to put it away for the winter.R1 Single Seat Mini Build!
    Jun 2015
    Alberta, Canada
    Quote Originally Posted by XJZ33 View Post
    Thank you for the kind words. It sure feels good to get it running under Its own power!
    Keep plugging away. You seem to be on a similar time line as I am, you build is coming along awesome.
    It is too cold around here in the winter to keep the work going, its too bad. I will keep my mind busy with my snowmobile, however, next summer Iíll be right back into it!
    Looks and sounds great! From the video it looks like you have a bit of chain “whip”......might want to consider a spring loaded tensioner sprocket on the bottom of the chain to “tame” the whip.
    Jun 2015
    Alberta, Canada
    Quote Originally Posted by ODB View Post
    Looks and sounds great! From the video it looks like you have a bit of chain ďwhipĒ......might want to consider a spring loaded tensioner sprocket on the bottom of the chain to ďtameĒ the whip.
    Thank you very much for the comment! You must be referring to the first chain coming from the output of the motor? Yes that chain will get some style of tensioner or slider. It is all adjustable at the back with sliding bearings but I am just working on getting that all dailed in!
    The chain kept coming lose on me so it is very possible it was whipping around in one of the videos.
  1. Single Seat mini buggy build Ideas
    By Linden318 in forum Frame
    Last Post: 03-02-2016, 02:08 AM
  2. pros sand mini single seat
    By swampthing in forum For Sale
    Last Post: 07-04-2015, 05:24 PM
  3. CBR 600Fi Single Seat Build
    By Blackman0809 in forum Projects in Progress
    Last Post: 11-25-2012, 06:55 PM
  4. New Mini Buggy - Single Seat
    By Trell1245 in forum Show off your toys in here!
    Last Post: 04-05-2011, 08:07 PM
  5. Terrell Extremes - single seat mini buggy build
    Last Post: 12-03-2010, 12:02 PM
