Page 36 of 36 FirstFirst ... 26 34 35 36
Results 351 to 354 of 354
    Re: R1 Single Seat Mini Build!
    Senior Member Linden318's Avatar
    Jun 2015
    Alberta, Canada
    Well, this put a hold on brakes. Rear uprights are too wide to allow the caliper to sit properly over the rotors. I am going to re design the uprights properly to work with a brake set up ( I originally thought about putting the brake on the jackshaft).
    Here are a few photos of my old (never was finished) sidewinder build beside my new buggy.
    Few odds and ends worked on.
    Jun 2015
    Alberta, Canada
    I have been putting a fair bit of time into the rear end (drive system and jackshaft) of my buggy. I got the secondary chain tensioner installed and the adjuster bolts to adjust the primary chain tension.
    The chain tension is a 1/2 ready rod shaft supported by 1 turnbuckle linkage currently. I had a fair bit of feedback on Facebook saying that upon downshifting the slack (now tension side) of the chain will see very high tensile loads. For this reason, I am going to add a second turn buckle linkage to help avoid any wrecks. Hopefully it holds after that!
    Nice!!!
    CWI CWS CWE
    The Sidewinder!! I remember those plans. You mounted the engine right next to you so you could periodically pat it on the head for a job well done!!
    It doesn't look like it would take much to finish the Sidewinder. What made you abandon the project?
  1. Single Seat mini buggy build Ideas
    By Linden318 in forum Frame
    Last Post: 03-02-2016, 01:08 AM
  2. pros sand mini single seat
    By swampthing in forum For Sale
    Last Post: 07-04-2015, 04:24 PM
  3. CBR 600Fi Single Seat Build
    By Blackman0809 in forum Projects in Progress
    Last Post: 11-25-2012, 05:55 PM
  4. New Mini Buggy - Single Seat
    By Trell1245 in forum Show off your toys in here!
    Last Post: 04-05-2011, 07:07 PM
  5. Terrell Extremes - single seat mini buggy build
    Last Post: 12-03-2010, 11:02 AM
