Page 34 of 36 FirstFirst ... 24 32 33 34 35 36 LastLast
Results 331 to 340 of 357
    Re: R1 Single Seat Mini Build!
    Senior Member Linden318's Avatar
    Jun 2015
    Alberta, Canada
    Thanks guys appreciate the comments !
    I would love to head south to the dunes someday, it sure looks like cool country to explore down there!
    Well, you have the tar sands in Alberta. That's close to the same thing, right?
    Jun 2015
    Alberta, Canada
    Lol! Thatís close, just have to dodge some machinery and security R1 Single Seat Mini Build!
    Jun 2015
    Alberta, Canada
    Fuel system is installed and ready to go. I had the buggy engine up and running the other day.
    Moving to the rear of the buggy and working on drive train. More redoiní andfixing old work.
    Update to come soon.
    Looks very good. Glad to see you’re strapping the fuel tank in place. No cracking that way.
    Jun 2015
    Alberta, Canada
    Looks very good. Glad to see youíre strapping the fuel tank in place. No cracking that way.
    Thanks K-Fab! Yes, I built the cradle and will run two straps over the top to hold it in place.
    I am going to put a 1/8Ē thick aluminum firewall between the exhaust headers and the fuel tank, do you think I will need more heat shield to avoid having issues with the fuel tank? Like an exhaust wrap or a heat reflecting tape on the fire wall?
    On the Tazcars we ran just a 1/16" wall between the engine and the tank. There's a lot of air flow, heat tends to travel up, there is an air gap between the wall and the tank, the tank has a lot of mass (fuel) to heat up, blah, blah, blah... Nah, probably not but if you're worried, get some of the self adhesive aluminum sheet insulation stuff like this: https://www.summitracing.com/parts/hsp-170102 Summit carries another brand that's a lot less but I can't find it presently.
    Jun 2015
    Alberta, Canada
    Perfect, I already have a bunch of 1/8Ē aluminum sheet to use up so I may just use what I have. Iíll look into 1/16Ē, I assume that is better fit for most panels and dash and such?
    Or maybe Iíll go with thin plastic puck board...? We will see I guess.
    Thank you for the link, Iíll look into it.
    Jun 2015
    Alberta, Canada
    Update on the build. The surge tank was leaking through the bolt studs that I welded on the inside of the tank. I guess there must have been some pin holes I could see when I finished welding.
    I built a new lower plate, threaded it and used thread sealer and lock washers to hold the studs from the inside of the surge tank.
    This allows the fuel pump to bolt in with sealed studs.
    Also replaced the fuel pump o-ring.
    Old bottom cut off surge tank.
    Thread sealer on bolts. Gasoline safe according to the tube
    Rebuilding rear jackshaft mounts and shaft.
    Fuel tank straps
    Eye bolts will get shortened.
    Jun 2015
    Alberta, Canada
    Jackshaft turning down to correct diameter.
    Jig for the lathe. Used to cut the keyway in the shaft. Iíll show it in later pictures.
    Just have to finish welding the sprocket hub and then the jackshaft will be done
  1. Single Seat mini buggy build Ideas
    By Linden318 in forum Frame
    Last Post: 03-02-2016, 01:08 AM
  2. pros sand mini single seat
    By swampthing in forum For Sale
    Last Post: 07-04-2015, 04:24 PM
  3. CBR 600Fi Single Seat Build
    By Blackman0809 in forum Projects in Progress
    Last Post: 11-25-2012, 05:55 PM
  4. New Mini Buggy - Single Seat
    By Trell1245 in forum Show off your toys in here!
    Last Post: 04-05-2011, 07:07 PM
  5. Terrell Extremes - single seat mini buggy build
    Last Post: 12-03-2010, 11:02 AM
