Page 3 of 31 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 309
    Re: R1 Single Seat Mini Build!
    #21
    Possibly from a late 90s Argo. ( skid steer amphibious atv) any numbers of any kind on it?
    #22
    Okay that would make sense, I will have to check tomorrow to see if there are any number! Thanks
    #23
    Senior Member Beruba's Avatar
    Feb 2014
    Alberta Canada
    If the ratio work for you it will be awesome. There is a diff in that gearbox.
    http://www.argoxtv.com/sites/default...No%2034521.pdf
    #24
    The one Beruba posted is much newer and completely different from the one you have. But either way the ratios are probably not what you are looking for if that tranny is what I think it is it would have been behind a 20 hp Twin 4 stroke and at around 3500rpm on 22" tire you would see 25-30km/h max. They are well built for the intended purpose but I have my doubts behind a r1.
    #25
    Hey thanks guys for all the help. It does have a diff in it which would be nice but I don't think this gear box will be worth it if it is only intended for a smaller engine at a lot smaller speeds. The reverse would be nice, although I do not want to have this all set up in my buggy and start wrecking gears in the tranny!
    #26
    It might be worth doing some research into whether it can handle the R1 though, HI and LOW range with Reverse. There are guy's on 6X6 world that put Suzuki 1.0l G10's in them running that gearbox. I dont know what kind of horse power the R1 has but a stock G10 is I believe 55HP. I have an Argo Conquest 8X8 with that transmission, I was on 6X6 World and saw the G10 transplants. This got me thinking and well full circle I am on MBN because the G10 I acquired was in a little home built buggy and now I am makinng it better rather then the Argo.
    A link: http://www.6x6world.com/forums/argo-...gine-swap.html
    #27
    Hey Carson. I may have to do some more research, the r1 engine has around 170hp. It would be awesome to be able to use the gearbox, especially Hi/Low and the reverse. I will keep looking to see. Thanks!
    #28
    Yeah 170 might be a bit much. The Argo in that thread is by no means babied and he never reported any drive failures that I remember however you're talking about an additional 120 HP. It would be awesome but, probably not for very long.
    #29
    Check the ratio, might be a quick decision.
    #30
    Yea I think that this engine may be a little much for that box. I will probably just run chain drive to a spool and deal with the fact I won't have reverse. Or rig something up. I will check the ratio although.
  1. Single Seat mini buggy build Ideas
    By Linden1234321 in forum Frame
    Last Post: 03-02-2016, 01:08 AM
  2. pros sand mini single seat
    By swampthing in forum For Sale
    Last Post: 07-04-2015, 04:24 PM
  3. CBR 600Fi Single Seat Build
    By Blackman0809 in forum Projects in Progress
    Last Post: 11-25-2012, 05:55 PM
  4. New Mini Buggy - Single Seat
    By Trell1245 in forum Show off your toys in here!
    Last Post: 04-05-2011, 07:07 PM
  5. Terrell Extremes - single seat mini buggy build
    Last Post: 12-03-2010, 11:02 AM
