Results 1 to 6 of 6
    Kawasaki V Force 700 for a power source?
    So my daughter really wants me to build her, her own little buggy. I've been thinking about this for a couple years. Anyways, what are your guys thoughts on useing a kawasaki 700 V force for the power source. This would give her an automatic and reverse. Plus its shaft driven, which should be more durable verses a chain drive. I should also be able to quite it down enough for trail riding. Wouldn't have enough to push it hard through the dunes, but would be more than enough for camping and trails. More I think about it, I think it sounds kind of fun.
    http://www.atv.com/manufacturers/kaw...view-1757.html
    Re: Kawasaki V Force 700 for a power source?
    Member crazy's Avatar
    Dec 2007
    Douglasville, Georgia
    I have a kfx700 and also would like to make a buggy from it. I thought about a diff out the front of motor to Run dual swing arm setup for rear. These have a lot of power.
    Dec 2015
    Near Pittsburgh, PA
    I am sure that engine will be great for you.
    Wondering how the shaft drive is set up with the CVT.
    Is like a Polaris gearbox?
    Quote Originally Posted by MASCMAN View Post
    It's similar. I would probably use the rearend out of a kingquad, that is setup for independent suspension already.
    Dec 2015
    Near Pittsburgh, PA
    I was thinking, cut the axle and weld on plates to mount CVS to.
    Senior Member lost26's Avatar
    Highland Village Tx
    The king quad idea sounds pretty good.. keep us posted
  1. Can you buy v force 3 rubbers only
    By LEE1969GB in forum Motor - Engine
    Last Post: 02-10-2009, 06:07 AM
  2. Luke at Force tek racing ( formerly sonic)
    By Quadrockets in forum Projects in Progress
    Last Post: 02-12-2008, 04:20 PM
  3. Air force test....?
    By nutz4sand in forum MiniBuggy.net Lounge!
    Last Post: 01-17-2008, 06:10 PM
  4. CV source
    By Lawngodfather in forum Driveline
    Last Post: 02-20-2006, 11:21 AM
