Page 1 of 20 1 2 3 11 ... LastLast
Results 1 to 10 of 195
    Check out my POS build! What is it?!
    Dec 2015
    Near Pittsburgh, PA
    I have been working on this project for a short time...gathering parts and information. Some pics scattered around the site here and there.
    Basically I paid too much for a worthless project just before Christmas...widow with 3 kids and my kind heart = empty wallet!
    A neighbor guy was selling it for the widow as the "Odyssey from Hell". After bringing it home and checking it out closer, I realized that I just bought a pile of junk...I actually knew it while loading it up!
    This build is a more frugal build than most as it will just be for a weekend here or there. My wife is into the Harley more and I have spent lots on it which is basically our main toy so I have to keep it low key on this build.
    The POS build:
    Polaris 530cc 2 stroke twin cylinder sled engine and Trailboss FNR gearbox
    Odyssey frame section...basically used it just to say I used it!
    Shredder II suspension from the plans.
    Parts List for my reference
    300.00 1973 Polaris 530cc twin cylinder 2 stroke with 36mm Mikunis
    200.00 1987 Polaris Trail boss FNR gearbox - 13t countershaft sprocket
    1987 Polaris Trail boss drive and driven pulleys
    117.00 2008 Polaris Outlaw 525 IRS Rear Shocks
    117.21 2004 Polaris Predator 500 Front Fox Shocks
    14.95 2003 Cannondale 440 Rear Brake Rotor
    25.00 2001 Kawasaki Vulcan VN1500N Front Brake Caliper for rear brake
    52.79 2004 Yamaha Raptor 660 front Spindles and Hubs
    34.61 2001 YAMAHA RAPTOR 660 front brake calipers
    96.20 1980's S-10 CV Axle Shaft w/o ABS GM Front Driver/Passenger 80-1501
    54.09 1980's S-10Wheel Hub Bearing Assembly Chevy GM 513013
    275.00 ITP 56A373 Mud Lite AT Tire 25x12x9 Rears
    ITP 56A326 Mud Lite AT Tire 23x8x10 Fronts
    69.45 11" Rack & Pinion
    32.56 1.250" Pillow block bearings and split ring collars
    TBD Heims/ shafts, etc
    TBD Metals
    $1388.86
    Re: Check out my POS build! What is it?!
    Dec 2015
    Near Pittsburgh, PA
    So here is what I brought home. The engine seems to run good and althiough not really my first choice I have decided to go ahead and use it...for now at least.
    It had the engine pulley drive the pulley on the input of a golf cart rear (10:1 reduction)...brakes where stuck on but you could still drive it. I believe that is the only way the kids where able to ride it without getting killed. I pulled the caliper off and took it for a ride...got a little hairy to say the least. With no kill switch it was just stupid!
    Dec 2015
    Near Pittsburgh, PA
    So...after checking out all the awesome builds on here I got excited to try and make something out of this.
    I decided on 3 things.
    1. I would use the frame and some of the cage so it kind of resembled what the wife saw me bring home...camouflage basically.
    2. I will use the engine since it runs and should put out some decent power.
    3. I will lie about any money I have spent on it!
    Started stripping it down and ordered my Shredder II plans.
    Here is a video of the motor actually running...the recoil rope wasn't in the whole way so it made a racket but I believe I can tune it to run pretty good.
    Dec 2015
    Near Pittsburgh, PA
    Got my Shredder plans and some metal and started building my "go kart".
    Using Raptor spindles modded to work with the plan's spindle design.
    Pressed the snout out of the Raptor spindle and cut up the aluminum.
    Simple shredder spindle.
    Quick and easy way to get disc brakes and easy to find replacement parts:
    Dec 2015
    Near Pittsburgh, PA
    You can check out the awesome Shredder build threads for better pics, but here is my front end.
    Got some Predator 500 front shocks and will be using Outlaw 525 rear shocks.
    After grafting the front end on the Oddy, I boxed the front frame in for strength and some gussets will be added later.
    Got some 23" Mud lites for the front and 25"s for the rear.
    Since this is for PA and OH woods riding, I think I will try for 14" ride height.
    Dec 2015
    Near Pittsburgh, PA
    Moving to the rear...will be using trailing arms based on the design of the Shredder but improved on by Lug...see his build in the Shredder forum.
    Dec 2015
    Near Pittsburgh, PA
    The trailing arms use heim joints and the S10 bearing assembly.
    Wanted more elbow room and helped to strengthen the frame.
    Dec 2015
    Near Pittsburgh, PA
    Trailing arm mounts:
    So simple but it works!
    Dec 2015
    Near Pittsburgh, PA
    Here we are now with the proposed cage design. I'm using square tube...almost broke down and bought a tube bender but I stayed the course! You can see my machine shop to the right!
    This is where I'm currently at. Like I said, it's not as pretty as the builds on here, but should be a decent wood/trails buggy when done.
    I am giving my daughter the buggy she has ridden all over Wellsville, OH in...it's a Manco Deuce with a 20HP Vanguard on 23" and 25" Dirt Devils.
    What a fantastic project! It's come from the right place (your heart), so it's a good deal from the start.
    I think you've got the beginning of a fun ride - it looks good.
    Wellsville, eh? I never made it there, but always heard it was a fun place.
    btw - I love the name of the project. Too funny.
  1. ST2 LT project build
    By Lorduss in forum ST2
    Last Post: 04-13-2016, 11:56 AM
  2. Two seater mini buggy build, side by side
    By PeteNado in forum Projects in Progress
    Last Post: 08-29-2014, 04:39 AM
  3. new 4 seater build project---need ideas on engine n trans to use
    Last Post: 01-08-2013, 09:24 AM
  4. The Groutaone channel on You Tube , a crazy buggy build
    By stress in forum Projects in Progress
    Last Post: 11-25-2012, 12:36 AM
  5. Milestone MX Park Riverside Ca
    By psychoholic in forum Events and Group Gatherings
    Last Post: 10-24-2011, 11:52 PM
