Results 1 to 8 of 8
    Rear camber problem help needed
    Hi everyone, I got that rail over the summer for like nothing and started to finish it up. It is almost done but I am having a small problem. The rear wheels have way too much positive camber. I think the shocks needs to be changed but I don't know and don't have much cash for it and shocks are expensive. I have put straps to limit the amount but it still too much, see picture below. I tried to adjust the camber but there is no way to do it on the hubs or anywhere, I am starting to think that the rear end is not complete and it is missing a link and a camber kit? Let me know what you guys think, thank you in advance
    Click on link below to see pic thanx
    https://www.flickr.com/photos/97377812@N08/19969958244/
    Re: Rear camber problem help needed
    Petoskey, Michigan
    The pics not working for me.
    Swing axle, nothing you can do about it and it's normal for that type of design......
    www.SinisterSandSports.com
    918-521-3736
    Really, is it safe like that? I strapped it at 22inch, should I let it go further with even more camber? It stances on the ground is neutral camber. Right now I have 4 inch down and 4 inch up travel, and my rail rear lowest point, the sprocket has 6 inch clearance, so I should be good? It seams that it was setup for dual shocks, it has dual mounts on each side, should I ditch these shocks and get dual all around? And what should I get?
    Thanx in advance
    Should I use a camber compensator kit?
    Jan 2009
    Los Angeles
    That's how a swing axle works. You can limit the travel to get less Camber but you will lose travel. Ford Rangers have been jumping with crazy camber changes for years along with VW rails.
    There's really nothing you can do unless you convert the rear to A-arm setup or Trailing arms.
    Ok thanx, if it's safe it's fine with me, actually I like the look
  1. Installation Problem: FL400 Rear Wheel Hub Assembly
    By weedan01 in forum Honda's Pilot & Odyssey
    Last Post: 02-18-2012, 04:21 PM
  2. Rear Suspension ?
    By Duden89 in forum Suspension - Wheels & Tires
    Last Post: 10-12-2009, 07:48 AM
  3. rear chain drive trailing arms help....
    By tannere in forum Driveline
    Last Post: 09-29-2009, 02:39 PM
  4. Drakart rear studs needed!?
    By litespeed in forum MiniBuggy.net Lounge!
    Last Post: 10-01-2008, 01:38 AM
  5. Complete List needed for builders
    By Battleborn in forum MiniBuggy.net Lounge!
    Last Post: 01-14-2008, 02:50 AM
