Page 24 of 24 FirstFirst ... 14 22 23 24
Results 231 to 234 of 234
    Re: One more buggy build in the mix...
    Senior Member iflytii's Avatar
    Jan 2013
    OKC, OK
    Quote Originally Posted by boilermaker View Post
    Everything comes to those who work hard and keep on keeping on. Looks good!
    Thanks!
    If you don't mind, could you give me some rough measurements of the Subi engine and trans?
    -Front pulley to the center of the CV outputs
    -Front pulley of engine to the back of the trans.
    -Width of the bellhousing.
    -Width of the CV outputs.
    From my gathering, the width of the engine is around 32.5" and the height from oil pan to top of intake is 22" or so. Do these seem proper-ish?
    Thanks!!
    Justin
    Those seem pretty ballpark if I recall. I should have all those dimensions written in my notes at the house, but I can go down and measure in person if I can't find them (my motor and trans are at a buddy's shop).
    Sep 2008
    Allendale MI
    Thanks!!
    Justin
    Nowhere near the desert.
    Jan 2013
    OKC, OK
    Got a little work done this weekend with a few upgrades to the transmission. 4.44 gears and an OBX limited slip diff. You can also see the center diff lockout installed at the bottom of the picture.
    Justin, I measured my motor/trans and your width and height were pretty much spot on. The motor is about 16" from the bellhousing to the outside of the front pullies. The transmission is about 30.5" long. From the face of the bellhousing to the center of the output shaft is about 6 3/8". The output shafts are approx 10" wide, and about 12" wide with 930 flanges attached (out to out). The transmission width at its greatest width is 14", but it necks down pretty quickly.
    Sep 2008
    Allendale MI
    Quote Originally Posted by iflytii View Post
    PERFECT!!!!
    Thank you very much!
  1. TTGInc's Buggy Build 2.0
  2. Is This Too Wild A Buggy Build For You?
  3. My first buggy build!
    Last Post: 10-01-2014, 10:26 AM
  4. The Fab School/ I want to build a buggy
    Last Post: 12-29-2010, 08:02 PM
  5. New Buggy Build Web Site
    Last Post: 05-20-2010, 03:46 AM
