Page 23 of 24 FirstFirst ... 13 21 22 23 24 LastLast
Results 221 to 230 of 234
    Re: One more buggy build in the mix...
    Member kustomfab2003's Avatar
    Appleton, WI
    Thanks for the update. When it comes to Subi's, John at Outfront is the man!!! Many of my buddies in SoCal have his work in their rails for Glamis, Dumont etc.
    CWI CWS CWE
    Senior Member iflytii's Avatar
    Jan 2013
    OKC, OK
    Agreed, John is the man! He has helped us tremendously with our pesky questions, many times after hours or on weekends.
    Jan 2013
    OKC, OK
    Craig's buggy is alive! I'll get video of it posted when I can, but it's exciting to hear it come to life!
    Unfortunately, the vendor we purchased our CV parts from has flaked out on us. They drop shipped the inner CVs directly from RCV and those arrived quickly (over a week ago), but the boots and flanges are MIA. No tracking, no response to email, no response to phone calls (voice mail full), kind of pathetic really. How hard would it be to provide some kind of tracking info, or status indicating they shipped or were on back order. Anyway, so now the only thing lacking a test drive are inner CV boots, ugh! I think Craig is going to attempt to just make a flange that allows the inner boot from the F150 CV assemblies we purchased since we have those laying around.
    Heck, if he knocks that out this morning, I'll have not only a first start video, but maybe even some action footage later today!
    Edit, Video of startup:
    Dec 2014
    Detroit, MI
    Sounds Good!
    I use f150 boots from Orielly auto parts. Modify the boot flanges so the cv balls will roll into.
    Jan 2013
    OKC, OK
    Our problem was we didn't have flanges. When Craig ordered his CV's, he ordered boots and flanges at the same time. CV's were drop shipped from RCV, the other stuff never showed up. We contemplated just stretching our leftover f150 boots over the 930 CV joint case, but the bolt heads really would have worn holes in the boot quickly if the boot would have even stayed on the CV without a flange. He ended up having to over-night the missing items from a different vendor.
    The new order arrived yesterday as promised, and the buggy has now moved under its own power! Shakedown run went well with only a couple needed tweaks so it is getting loaded in the trailer and headed to Little Sahara tomorrow!
    Dec 2014
    Detroit, MI
    That's Awesome! Post some videos of the test run
    Jan 2013
    OKC, OK
    Well, good news and bad news...
    Craig made it out to the dunes and got some seat time!
    Unfortunately, one of the "shortcut" last minute decisions needed to make the trip kind of backfired. We didn't have enough time to get axles prior to the trip, so we used the F150 axles by splitting them and using a section of tube in the middle to lengthen them for a temporary solution, and, well, we should have used thicker tube, lol. This was supposed to be a shakedown run, but without realizing it, air was being had, and one of the landings must have caused the paddle to dig into the wet sand and that made quick work of the axle. This happened Friday, and I hadn't even made it out there yet with the go-pro, so sadly there is no video of it running.
    So now proper (solid) axles are on order, and we can start working on the remainder of the to-do list on this buggy as well as getting the other one caught up.
    Sep 2008
    Allendale MI
    If you don't mind, could you give me some rough measurements of the Subi engine and trans?
    -Front pulley to the center of the CV outputs
    -Front pulley of engine to the back of the trans.
    -Width of the bellhousing.
    -Width of the CV outputs.
    From my gathering, the width of the engine is around 32.5" and the height from oil pan to top of intake is 22" or so. Do these seem proper-ish?
    Thanks!!
    Justin
    Nowhere near the desert.
    Sep 2006
    Groves, Texas
    Everything comes to those who work hard and keep on keeping on. Looks good!
  1. TTGInc's Buggy Build 2.0
  2. Is This Too Wild A Buggy Build For You?
  3. My first buggy build!
    Last Post: 10-01-2014, 09:26 AM
  4. The Fab School/ I want to build a buggy
    Last Post: 12-29-2010, 07:02 PM
  5. New Buggy Build Web Site
    Last Post: 05-20-2010, 02:46 AM
