Page 199 of 202 FirstFirst ... 99 149 189 197 198 199 200 201 ... LastLast
Results 1,981 to 1,990 of 2013
    De Pere, WI
    CWI CWS CWE
    May 2013
    Easton, PA
    You are going to clear coat this beautiful thing as-is, correct? Be a shame to put color on it lol. I know you had to have tested it, (you'd better have!) but why does that lower rear frame tube look like it would be in interference mode with the trailing arm in bump travel?
    Quote Originally Posted by Xbird View Post
    I keep thinking I should just clear powder the suspension - it does look sweet with the color changes in the metal and such.
    There's a pocket in the rear cage that the arm comes up into so it doesn't hit the frame. Lots of things get really close to other things as the suspension cycles but nothing's hitting yet - test runs will shake that out.
    May 2013
    Easton, PA
    3m paint and rust stripping wheels would clean up the tubing around the welded joints and leave a little of the heat bluing. finish the tubing clean up, some swirl work on the panels and a faint touch of a pearl or metallic color in the clearcoat ... could always go to a full color after, but would be hell to get it back to how it looks now after a full color job.
    May 2013
    Battle Ground, WA
    While I gave up on my MiniBuggy project forever ago and sold it for parts.... YOURS TURNED OUT TO BE THE COOLEST THING EVER. Do you have a photo album that I could just cruise through?
    Quote Originally Posted by rumorco View Post
    Hey! Haven’t seen you here in a while.
    Thanks for the compliment. Unfortunately no, I don’t other than in this thread.
    One thing you might be able to do.....some forum software has an available feature under “thread tools” that allows you to “view attachments” as a menu opinion......it might just be a matter of you flipping a switch as admin to “allow” that feature......or maybe not! ��
    Quote Originally Posted by ODB View Post
    Not with my setup. I host the pix on yellowdogracing and link to them.
    Back from Thanksgiving vacation and then having to be responsible. I get to play again. Yay!Got the 12v AC compressor mounted today. It will be getting a shroud and possibly ducting from the ac to keep it cool. It's behind the radiators and it's not supposed to like being above 70C (158F) so I'll make sure it's happy.Nuuuuut Pockets. (:
    De Pere, WI
    Nice!!!
    CWI CWS CWE
  1. Mini Lite's: Race Car
    Last Post: 03-28-2014, 05:39 PM
    Last Post: 09-24-2012, 08:02 AM
    Last Post: 03-19-2012, 11:34 PM
  4. Mini A Arm Buggy for Kids
  5. 2 Seat Mini 4X4 Buggy
