Page 171 of 174 FirstFirst ... 71 121 161 169 170 171 172 173 ... LastLast
Results 1,701 to 1,710 of 1739
    Member kustomfab2003's Avatar
    Appleton, WI
    Nice, keep the progress posts coming. I'm so glad my house didn't sell or I might have taken you up on your earlier $25K price point. :-).
    CWI CWS CWE
    Slick!
    Things are happening.
    Engine and trans system are mounted.
    Cooling system is finished (except for where I plumb in the HVAC system a bit later)
    Fuel system is 90% - still have to make the bung that the return line goes to and weld it to the tank.
    Billet! Pump mount in process:
    Pump mount (insert "tada!" sound):
    Bench fitting test - perfect!
    Frame fitting test - perfect!
    She's tight but everything clears and has room to vibrate and move a bit:
    I'll get the final piece for the return line done today and hopefully tacked into place on the tank (tank is a bitch to install/remove - may have made it a tad too big up top but it fits).
    Once that's done it's exhaust system time. I have the stock Nytro system in hand and want to see how much of it I can use. Not sure it's going to be quiet enough, though. I want this thing to be whisper quiet so what muffler finally gets used is still a mystery.
    Sep 2005
    Pacific Northwest
    That pump mount came out nice!
    Quote Originally Posted by rowycoracing View Post
    Thanks
    Messing with the exhaust system. Looks like I'm placing an order with SPD here in a bit. Can't use squat off the stock system except the header flanges.
    Four J bends, a 3 into 1 collector and two feet of stainless tubing on order from SPD.
    Got the stock muffler installed half way.
    The stock mounts are two on each end and one set on top, one set on bottom. I cut the bottom mounts off the exhaust end and made a new upper mount. I'll stick with the two per end setup and knock out another one tomorrow.
    The two back mounts get screwed into inserts in the frame:
    Here's it's new home:
    I'll do two ears off the tubes that the front pair of mounts will attach to next.
    Nice!
    You've been busy.
    Jul 2005
    Melbourne, Australia
    Sweet machine work as usual K, all the little things hog the clock but make it so much sweeter����
    Ride it like you Stole IT!!!
    Senior Member whitedragon64's Avatar
    Oct 2008
    Perth Australia
    Nice work K Fab, must be beginning to see light at the end of this tunnel now
    Sep 2008
    Allendale MI
    Any information regarding the exhaust bushings you have on the muffler?
    Justin
    Nowhere near the desert.
  1. Mini Lite's: Race Car
    Last Post: 03-28-2014, 05:39 PM
    Last Post: 09-24-2012, 08:02 AM
    Last Post: 03-19-2012, 11:34 PM
  4. Mini A Arm Buggy for Kids
  5. 2 Seat Mini 4X4 Buggy
