Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    shocks for mini buggy?
    Jan 2012
    michigan
    Question
    OK so i am about to start my first build and i am wondering about shocks i have been thinking about fox 2.0 shocks with 16" of travel for the rear but im not sure if i should use fox 2.0s for the front or some kind of coil over also wondering about fox floats maybe any information is very much appreciated
    Re: shocks for mini buggy?
    Jan 2012
    michigan
    maybe the Fox Shocks 2.0 Emulsion 12" Travel
    Jan 2012
    michigan
    no one?
    you are going to need a coil over
    Fox Air 2.0 front and rear. Emulsion shock will need a spring to hold up buggy.
    Jan 2012
    michigan
    for the front shocks?
    For a light buggy, a 1.5:1-2:1 or more lever ratio is common. Do you plan on building a suspension with 24" of wheel travel?
    Where are you at in Michigan? I have a used pair of Bilstein 7100 Series shocks that gave 16" of wheel travel on the front of a Drakart Formula Cross. They are coil over, 2 1/4" ID springs with remote reservoirs.
    They gave 12.5" wheel travel when used on this setup:
    Jan 2012
    michigan
    yes I live in michigan. I'm john from Howells son. just planing my first build out. and no I'm not planing on having 24" wheel travel i just want some thing that will get me down a trail fairly smooth
    Jan 2012
    michigan
    what kind of springs do you have on the bilstien 7100s?
    The springs on that setup are 12" 80 in/lb 2 1/4" ID.
    If you are doing a small buggy with say 12" travel, then a 6" travel shock at a 2:1 lever ratio is a good setup.
    Since your Dad already has the 350, you might just consider getting another as a base. Even if you have your own ideas for customization, it is far easier to make the one change with everything else working. You can then apply the ideas that work out to an entire build later.
  1. TTGInc's Buggy Build 2.0
  2. Air Shocks
    By ringgo1star in forum Projects in Progress
    Last Post: 11-10-2012, 06:49 AM
  3. My custom mini buggy (similar to panther)
    By andy777bmx in forum Projects in Progress
    Last Post: 12-19-2011, 09:36 PM
  4. Videos of Midi Buggy. New Glamis vid/pics
    By TutTech in forum Show off your toys in here!
    Last Post: 01-31-2011, 05:43 PM
