Thread: Panther!
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    Panther!
    Mar 2012
    San Martin, California
    Hi guys! I am new so any advice is greatly accepted. So here we go.
    we have been working for the past 3 years and only seemed to get part of the driveline done. We also recieved a crashed honda CM450E. we took the motor out and started it up. The motor ran amazing.
    I have ordered energy suspension bushings for the buggy. I will be getting metal for the rear trailing arms today. I also am going to start on the frame very soon.
    i will put pictures up very soon of what I have got done. I am going to head for a more off road buggy but occassionally I will want to hit the dunes. I was going to run by the plans as best I could but if anyone has advice please tell me.I would love to hear it!
    Thank You
    Re: Panther!
    Mar 2012
    Here is what I got so far. Some of the parts here we are keeping that we will not actually use.
    I do have a question. What size sprocket should I use?
    Re: Panther!
    Feb 2009
    Baton Rouge area
    do you have pics of the frame? we always like to see pics. what kind of power does that CM450 have?
    Re: Panther!
    Senior Member turbotike's Avatar
    May 2011
    okotoks alberta
    Quote Originally Posted by fireboy View Post
    From wat i asked for my panther minumum 60 tooth for the rear stock front but that was for a 750 ninja.
    some are built not bought, most are built not thought.
    Re: Panther!
    Senior Member Gotted's Avatar
    Apr 2008
    Clarkston WA.
    Talking
    FireBoy Welcome to the site.
    You started your panther! thread, keep us up to date on your progress.
    I built 2 panthers if need advise or pics I mite be able to supply them. Turbobike is correct. Get a 60 to 63 tooth sprocket these are the ones you should have if you want run in sand. Count the teeth on the front sprocket less the better. The stock sprocket is probably ok.
    Re: Panther!
    Im putting 13 front 57 rear in my 99 gsxr 750. You want the lower gearing for more torque in ur buggy.
    Re: Panther!
    Jan 2007
    Slater Mo.
    12/60 here. I believe a 5:1 ratio is what seems to be the target for most builders. But you have to take actual tire size into consideration as well.
    Re: Panther!
    Mar 2012
    Hey thanks guys. I was thinking that but wanted to make sure I was correct. Here are some more pictures of the driveline stuff.
    These pictures are of the stud and the carrier to the hubs.
    Re: Panther!
    Apr 2008
    Clarkston WA.
    Are those Type 1 or 2 stubs axels for your trailing arm hubs.
    When are you going to make the rear trailing arm jig in the plans.
    Re: Panther!
    Mar 2012
    Those studs we made to adpat to a type 1 axle. Im working on the jig real soon. I wasnt able to get to the metal shop the other day so I have to wait till monday. I am also waiting for the suspension parts to come in so i can make the bushing mounts correctly.
  1. Panther Frame and Fox 2.0 shocks for sale
    By randybrinsley in forum For Sale
    Last Post: 02-07-2012, 09:49 AM
  2. Inherited Panther project
    By cmftlynum in forum Projects in Progress
    Last Post: 10-16-2010, 09:31 AM
  3. Will's Panther build
    By Will_lc8 in forum Projects in Progress
    Last Post: 01-14-2008, 09:00 AM
  4. solid axle on a Panther????
    Last Post: 11-17-2007, 03:27 AM
  5. Desert Karts Panther
    Last Post: 04-30-2007, 05:43 PM
