Results 1 to 9 of 9
    Baja SAE Inspired Buggy Build
    I have been browsing this site for many months and finally decided to start a build thread of my own. I also thought that maybe some outside eyes will help spur my motivation to make some progress again. The design has been in progess almost three years from when I started in 2009.
    This is a ground up inspired build from my time participating in the Baja SAE series. I spent approximately three years in the series and wanted to start a project that was similar, but not constrained to the SAE rulebook.
    I do not have a donor vehicle to start from so I been working from scratch. I will be posting pictures once grab some screenshots of what I have so far.
    Preliminary Targeted Features and Performance
    - Briggs & Stratton V-Twin (Targeted)
    - FNR Gearbox
    - CVT
    - Ground Clearance ~12in.
    - Suspension Travel ~6in.
    - Weight 500-550 lbs.
    - 30-35 MPH
    Re: Baja SAE Inspired Buggy Build
    Here is a picture of the frame so far. The majority of the tubing is 1.25in OD x 0.065in. wall. The rest is 1in. OD x 0.035 wall.
    missing link!
    (fellow baja guy)
    I'm not sure if you have seen this thread or not, but here is a link to the 13Motorsports Baja SAE based buggy with a Briggs & Stratton V-twin.
    https://www.minibuggy.net/forum/proje...n-vehicle.html
    I think you may want to increase your target speed! Vanguard (Briggs) v-twins have huge potential! If you are interested in making power with one, let me know! I happen to know a guy that knows everything there is to know!
    Until I can figure out how to eliminate the following error message when trying to post with Manage Attachments the following link will have to do.
    Error: b01x.jpg:
    Upload of file failed.
    Pretty cool. It seems to have the exact same dimensions than a Baja SAE. You seem to be using 1in tubing for the side members. I would suggest stepping up a size. Baja cars have relatively short life spans. You don't want to destroy your frame the first time you hit a tree or rollover.
    Double wishbones front and back. What shocks are you going to use? Custom uprights?
    Senior Member Gotted's Avatar
    Apr 2008
    Clarkston WA.
    Quote Originally Posted by kill9863 View Post
    Error: b01x.jpg:
    https://lh3.googleusercontent.com/-r...s620/b01x.jpg]
    You have to resize the pic to upload. These are the max file size's the server will accept.
    bmp 512.0 KB 620 620
    doc 19.5 KB - -
    dwg 2.00 MB - -
    dxf 5.00 MB - -
    gif 512.0 KB 620 620
    jpe 512.0 KB 620 620
    jpeg 512.0 KB 620 620
    jpg 512.0 KB 600 620
    pdf 512.0 KB - -
    png 512.0 KB 620 620
    psd 512.0 KB - -
    txt 293.0 KB - -
    xls 2.00 MB - -
    zip 1.00 MB - -
    "Imagination is more important than knowledge"
    How much are those Vanguard v-twins? I just looked for the 35hp one and it costs 1500usd on ebay. Is there a way to get them for cheaper?
    I wouldn't mind the simplicity of the B&S engine with the reliable power (35hp is pretty good) but for 1500usd you could get a 600cc or even a 1000cc engines from Yamaha/Honda/co...
    The best way to find reasonably priced Vanguard v-twins is to purchase them through either a lawn mower junkyard (they do exist), or to buy from a lawn mower racing forum (Also do exist), I suggest heymow.com.
    I would not purchase the larger Vanguards, because the smaller ~23hp ones are capable of giving the same hp with minimal mods. They aren't super cheap, but they are a great power plant to use for simplicity and durability. If interested in more Vanguard information pm me.
  2. Buggy # 2 looks like an another AR51 build
    By sodman in forum AR51 Buggy Group
    Last Post: 01-07-2016, 03:53 PM
  3. New here.. My Desert buggy Build
    By Vendetta20 in forum Projects in Progress
    Last Post: 01-23-2012, 02:29 AM
  4. r97's NX 250 mini buggy build!!!!!
    By r97 in forum Projects in Progress
    Last Post: 12-05-2011, 06:01 PM
  5. New Buggy Build Web Site
    Last Post: 05-20-2010, 02:46 AM
