Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 47
    Re: Continuation of an old project, 1st for me
    #21
    Quote Originally Posted by yoshi View Post
    Man, that is literally the very first design I had for my driveline when I first started, I have made significant changes and stopped running u-joint axles many many years ago.
    The weld is not unfinished, the inside is not welded, only the outside on that design.
    The threaded end for the castle nut should have ones side drilled for a cotter pin, the other side I just started welding the nut to the shaft on the inside as there was no reason to remove the nut on both sides.
    I would highly suggest changing out the rear end for my 930 stubs and running 930 cv's instead of the u-joint axles.
    I believe the bearing carriers are the same and the outside steal piece are the same (although I now have them machined out of a solid piece of steal instead of welding the ring on them), so you should only need my 930 stubs, which will replace the long shaft and the inner mount and allow you to run 930's.
    that busa guage their is it for sale and can you us it on a r1 2002 bike cuz i like the way it looks and price??
    #22
    Jun 2007
    san diego
    Thanks Yoshi, can you PM me on the price for the new stubs, I will call you to order them.
    JJ
    #23
    Jun 2007
    san diego
    Needed to take a break from doing the taxes and took some pictures. Dont gimme no BS about the zip ties and blue tape, they work good for temporary mockup The engine runs strong and purrs like a kitten.
    #24
    Jun 2007
    san diego
    More pics
    #25
    Señor Banned Member Chikin's Avatar
    I like the front spindles/a arm set up. Oh and I have the same zip ties mounts. No worries.
    #26
    Jun 2007
    san diego
    Slow weekend. Made the overflow bottle mount today. Hopefully get new stub axles next week and then the CV's and axles done. Redoing the wiring harness is such a pain. Will end up with a 12" LED light bar and 2 LED spots up top. The overall total wattage drawn with everything running should be @ 75% of what the system puts out, seems like no stereo at night time. New goal, Test drive in 3 weeks, I hope it not to hot out in the desert by them
    #27
    Jun 2007
    san diego
    New axles and CV's
    #28
    looks good nice job
    #29
    Jun 2007
    san diego
    Finally got my clutch and brake lines bled and the CV/Axles all greased up and installed. Was able to put it into gear and made it 2 feet when the fuel regulator diaphragm went out and fuel was pouring out the vacuum port. Lucky for me I talked to the tech at Aeromotive and he is sending me a replacement.
    Not sure why that happened all I ever put in there was unleaded and maybe hooked up the pump backwards once, lol
    Now all I need is the temp to drop down @ 90 in the desert for a real test drive.
    JJ
    #30
    Jun 2007
    san diego
    New pictures
  1. Sandrail Project From Argentina
    By nahueee._ in forum Projects in Progress
    Last Post: 12-12-2011, 10:45 PM
  2. First project
    By jjstime in forum Projects in Progress
    Last Post: 07-02-2007, 12:17 AM
  3. Project Logs
    Last Post: 05-21-2005, 06:41 AM
