Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 47
    Re: Continuation of an old project, 1st for me
    Jun 2007
    san diego
    Figured it out it is for the horn, the Orange was so faded it looked Yellow
    Jun 2007
    san diego
    Going to get the tank return line bung welded on, will also add in 1/8" breather the release tank pressure.
    Jun 2007
    san diego
    Pictures of the return line and breather port
    Oct 2008
    Ontario, Canada
    Nice work.
    Jun 2007
    san diego
    Today was a good day.
    Made a shifter mounting plate for the Desert Kart shifter with some aluminum and clamps. Check
    Mounted FNR shifter. Check
    Made up brake and clutch lines. Check
    Tomorrow:
    Throttle cable
    Shifter cable
    FNR cable
    Time for a drink
    Jun 2007
    san diego
    One more thing for tommorow, fire up engine again because it sounds sweet
    Jun 2007
    san diego
    Ordered the wrong type of push/pull cables, clip in type needed bulkhead 1/4".
    Anyone need these from JEGS;
    Qty Item
    1 555-15704 4-FT PUSH/PULL CABLE 3"
    This item is expected to ship 01/24/2013.
    1 555-15706 6-FT PUSH/PULL CABLE 3"
    1 555-15733 CLEVIS #10-32 X 3/16"
    2 555-15732 FEM ROD END #10-32 X 3/16
    Jun 2007
    san diego
    I have made significant progress but have not updated the log for a while, first things first though, get it running.
    All I need to do for a test run is get the axels done, but....if you look at the pictures I am posting the stubs are in question.
    1. There are 20 splines, cant figure out where those came from
    2. No holes drilled for the castle nut cotter pins
    3. Appears to be unfinished weld on the plate and shaft
    Should I just buy all new parts to match up to 930 or 934?
    What used 20 splines?
    In and out burger trays make great part trays
    JJ
    Jun 2007
    san diego
    Includung additional pictures.
    Rotor,Rotor Hat, Wheel Adapter Plate are made by Neal with wilwood brake calipers
    Vendor yoshi's Avatar
    Sep 2005
    Broken Arrow Oklahoma
    Quote Originally Posted by jjstime View Post
    JJ
    Man, that is literally the very first design I had for my driveline when I first started, I have made significant changes and stopped running u-joint axles many many years ago.
    The weld is not unfinished, the inside is not welded, only the outside on that design.
    The threaded end for the castle nut should have ones side drilled for a cotter pin, the other side I just started welding the nut to the shaft on the inside as there was no reason to remove the nut on both sides.
    I would highly suggest changing out the rear end for my 930 stubs and running 930 cv's instead of the u-joint axles.
    I believe the bearing carriers are the same and the outside steal piece are the same (although I now have them machined out of a solid piece of steal instead of welding the ring on them), so you should only need my 930 stubs, which will replace the long shaft and the inner mount and allow you to run 930's.
    www.SinisterSandSports.com
    918-521-3736
  1. Sandrail Project From Argentina
    By nahueee._ in forum Projects in Progress
    Last Post: 12-12-2011, 10:45 PM
  2. First project
    By jjstime in forum Projects in Progress
    Last Post: 07-02-2007, 12:17 AM
  3. Project Logs
    Last Post: 05-21-2005, 06:41 AM
