Page 156 of 156 FirstFirst ... 56 106 146 154 155 156
Results 1,551 to 1,553 of 1553
    Re: The Mad Minion - Gixxer 600 powered Micro 2 Seater build
    Bend, OR.
    Thanks!
    Got myself double booked for Labor Day dunes
    But the buggy has been doing good. I did have one small incident with the fan relay giving out the last time I had it out. I boiled over after stopping and looked down at 267F
    Let it cool and later tested to see the fan wasn't coming on and the relay went bad. So I tested running a basic relay off the switch so the fan is on at all times and temps stay much the same. previously I was hovering around 190-192F and the fan only came on intermittantly. Now temps hold at 188-190 and fan on all the time. I guess the water thermostat was mostly controlling before anybow.
    So out with the therstatically controlled fan relay and back to fan on by switch.
    Also a nearly bad lesson learned, watch your temp guages!! I could have melted down my beloved gsxr motor all due to a bad fan relay
    Bend-Tech Dragon Master
    Nov 2009
    Been there, done that, don't want to go back .
    Fan relays, fan fuses, you name it. MiniMax got a light thats hooked to the fan power, its on-the fan is alive.
    One thing I hate about the bike cluster is it likes to get stuck on check on startup, no temp gauge. About ready to wire a gauge cluster reset button
    Aug 2019
    Murrieta, CA
    Sorry for bumping a 5 year old post here, what happened next did the shocks get dialled in?, how's the trailer holding up?, and what's going on with the quad chain lubeing system tests. I got that cliffhanger feeling.
    I am new around here, its taken me quite a few months to read all 156 pages. I have loved reading this and learned a lot that my and my son we will be applying to our build. Dose any one know if this story continues else where?
  1. Replies: 110
  2. XCALIBUR first 2 seater build !!!!!!!!!!!!!
    By Xcalibur in forum Projects in Progress
    Last Post: 01-29-2009, 11:50 AM
  3. Another busa powered 2 seater...
    Last Post: 01-10-2009, 09:37 AM
  4. for my next buggy i want to build a 2 seater
    By magnum4598 in forum Projects in Progress
    Last Post: 01-07-2009, 01:00 AM
  5. 3.5L powered 2 seater
    By LockedupXJ in forum MiniBuggy.net Lounge!
    Last Post: 10-01-2008, 08:11 PM
