Results 1 to 10 of 17
    my makycuda in progress :)
    Re: my makycuda in progress :)
    Jan 2009
    Looks good!
    I'm curious about the end result.. how it will look with all your ajustments
    The engine sounds good!!
    Good luck with your build, I will follow it
    Tnx , I can hardly wait to make a test drive ..
    I put new pictures and movies with time
    first run (broken shaft joints)
    YouTube - makycuda5.avi
    Sounds good!
    What shaft joints did you use?
    I used homokinetic and universal joint and universal was too weak,I put a new stronger and I will post images
    http://img412.imageshack.us/img412/5919/zglob.jpg
    If the picture is the new setup it would not give me comfort. The angle is significant and it appears to be the type intended for slow rotation, like a farm implement.
    What will you do if this one fails?
    No, on the pic is old broken joint, the new one is still under construction, and the angle is not so inclined when run
    Apr 2007
    Riverside, CA.
    Way to go on the build.. nice. Sorry about the parts but that is all part of the build. You build and learn and you will improve on the weak part and fix it and have it back up and running soon.
    Me I like a new build for the challanges it brings and the fun of the build. I like to try new things.. yes they may not work but thats ok that is why I am trying new things to see what does or does not work.
    You can always find a way to improve or fix something. But not everyone can build a buggy. You did.
    Yes do to probably cost of parts or parts on hand you used that part.. it broke and you will either upgrade, improve on or buy a bigger part. It happens. The point is you can always improve once you have atleast built the buggy there is always room to grow. That is a huge part of the reason I build buggies. I like that challange and the building and growing of a buggy. Shoot one of my cars grew into a race car.. who knew! ha ha.
    Very cool let us know how you fix it and keep us posted on how it is holding up etc.
    Nice build, good job.
    thanks very much, I enjoyed building it ,I am 26 and I have a lot to learn ..., I'll post you new pic/videos
  1. R82s almost in progress
    By The Kar Audio Guy in forum Projects in Progress
    Last Post: 12-17-2010, 10:38 PM
  2. ST2 LT In Progress - Help me overcome its flaws :)
    By Daniel Dk in forum Projects in Progress
    Last Post: 06-21-2010, 03:13 AM
  3. My buggy in progress
    By flyingpig in forum The Drawing Room
    Last Post: 08-15-2008, 04:43 PM
  4. Stealth Sand Cars premiere in progress !!!!!!
    By stealthsandcars in forum Projects in Progress
    Last Post: 08-05-2008, 05:58 AM
  5. Blogs vs. Projects in Progress
    By Kludge in forum MiniBuggy.net Lounge!
    Last Post: 04-10-2006, 10:01 PM
