Results 1 to 6 of 6
    Polaris Trail Boss 325 type transmission x2!!
    Senior Member mech_head6's Avatar
    Mar 2009
    Milwaukee, WI
    I've had a pair of these transmissions around since we pulled them out of Autumn.
    1x 2wd Trail Boss type transmission. (Also used in some Sportsman and Scrambler?)
    1x similar type transmission with broken case (Not capable of 50hp at race pace)
    3x or 4x misc sprockets for output
    1x mechanical speedo drive
    1x input shaft 'trans brake' converted for alternator pulley
    1x P90 secondary clutch (missing spring)
    ?x Grease and grime.
    Reference: Discussion about application
    https://www.minibuggy.net/forum/pay-f...aris-fnrl.html
    FREE to good home!
    (you pay shipping)
    Located near Milwaukee, WI
    (frequent-ish travels towards Twin Cities, MN and the UP)
    • Engine - 2016 RZR 1k XP
    • Transmission - RZR 1k XP
    • Chassis - 2012 RZR 570
    • Suspension -
    Re: Polaris Trail Boss 325 type transmission x2!!
    What is the shifting pattern like? I have a home built electric car that would actually benefit from a Low/High gear ratio (and the reverse would save me electrical complexity). Is the Pattern H-L-N-R?
    Thanks!
    Dain
    Mar 2009
    Milwaukee, WI
    I'm not sure. Would have to check, but leaving town for work until Fri.
    • Suspension -
    I'll take it anyway - sent you a PM with my address, no rush whenever you get a chance.
    Mar 2009
    Milwaukee, WI
    Sent. Hope it helps!
    • Suspension -
    heck yeah I'll put it to good use!
  1. Polaris transmission
    By lost26 in forum Driveline
    Last Post: 09-16-2014, 12:11 AM
  2. Racing Cost & Information for each Class.
    Last Post: 08-17-2014, 11:00 PM
  3. Formula Desert Lites
    Last Post: 07-22-2013, 10:22 PM
  4. Will Polaris Transmission Handle M/C Engine Power?
    By Kawabuggy in forum Driveline
    Last Post: 11-26-2008, 09:07 PM
  5. Replies: 4
    Last Post: 11-08-2007, 09:41 AM
