Results 1 to 8 of 8
    Air Replenishment Valve
    What is the purpose of an Air Replenishment Valve? I bought an aftermarket exhaust without the hookup for it. What does it do and can I live without it?
    Sorry for the noob question. I searched but received no results. Googled and only found valve adjustment how it's.
    Re: Air Replenishment Valve
    What engine are you using the exhaust on?
    I race, therefore I am
    Sorry, a 150cc GY6 A block.
    Got before and after pix? Where does it attach (other than the exhaust?)
    I can try to take a pic later. It connects to the carb. I'm starting to think it's emission related.
    May 2015
    Northern California
    Pic? Chances are it is for emissions and can be plugged off on the carb without ill effect. Make sure you have no vacuum leak though. Just a suggestion, but you could try getting it running well with the stock exhaust and the valve hooked up, then unplug the valve at both ends and cap both ends. If it runs well like that, you can probably run it capped with the new exhaust.
    Dune 500
    YXZ1000R
    Desert kart "Panther" build
    Yeah, I can't figure out how to post a pic. I think it's similar to an EGR valve setup. I'm just gonna run without it. Also the hammerhead intake doesn't allow me to hook up a PCV. That one is a definate gotta figure something out.
    If you happen to have a web host for pics, put them there and then link to them here.
    Example (without spaces): [img ] full url of picture [/ img] That will post ‘em up.
  1. To eliminate or not?? Exhaust control valve
    By mmobley in forum Motor - Engine
    Last Post: 12-06-2013, 03:56 PM
  2. Vacuum Fuel Valve
    By Fluke in forum Motor - Engine
    Last Post: 01-26-2012, 06:29 AM
  3. VW valve lash...
    By dbiggs in forum Motor - Engine
    Last Post: 06-23-2010, 05:49 PM
  4. Blow off valve question.
    By yummi in forum Motor - Engine
    Last Post: 06-29-2008, 08:13 AM
  5. Brake Proportioning Valve
    By GaryMX in forum Controls and electrical
    Last Post: 02-22-2007, 10:01 PM
