Thread: ZX1400 CFM
Results 1 to 10 of 10
    ZX1400 CFM
    Senior Member NFG's Avatar
    Jan 2009
    Australia, Canberra
    Hey Guys,
    Can anyone tell me what the CFM (cubic feet per minute) is for a zx1400?
    The only info i can seem to find is that the stock paper filter is 164.7 CFM.
    The reason i need to know this is i want to make sure i buy the right donaldson air cleaner for my buggy as i'm not happy with the setup i'm using at the moment.
    cheers.
    Re: ZX1400 CFM
    (1400 cc x 11K rpm)/2 (since each cylinder only drinks every other revolution) = 7.7 million cc = 7,700 liters
    7.7k liters (punch into converter on iPhone) = 271.9229338 CFM
    quick disclaimer - I may be VERY WRONG!!! LOL - it's about double what you're finding so maybe I've missed a divide by two somewhere.
    Donaldson setup eh? Gee, where'd you get that idea?
    https://shop.donaldson.com/store/en-...25&catNav=true
    Re: ZX1400 CFM
    Jan 2009
    Australia, Canberra
    Thanks mate!
    I didnít know how to calculate it correctly.
    As for the Donaldson air cleaner not quite sure where I seen or heard about it...😜😁
    Re: ZX1400 CFM
    You did see the "I MAY BE VERY WRONG", didn't ya. (:
    Re: ZX1400 CFM
    Jun 2014
    Upper Peninsula, MI
    I think that math would be assuming 100% volumetric efficiency, so the real number is likely less than that. How much less, I couldn't tell you though
    Re: ZX1400 CFM
    Blog Entries
    1
    While the actual numbers may be technically lower, they are based on zero restriction. Since you are going to have restriction in the filter, it's better to shoot high. Be aware that all flow ratings are not equal. You need to look at how many inches of water the rating is at. Most Donaldson filters have a "saftey" secondary filter than can be removed for more flow.
    Re: ZX1400 CFM
    Oct 2009
    air flow rate=cid x rpm x 0.5 x Ev
    ________________
    1728
    example small block ford 302 cid,rpm= 5500, and Ev =85%
    Air flow rate = 302 x 5500 x 0.5 x 0.85 =408 cfm
    1728
    Re: ZX1400 CFM
    See! I told you I was wrong. I went for simple, straight forward "It can move this much air".
    Re: ZX1400 CFM
    Oct 2009
    When I made up my turbo system for the Taz I ordered three books on turbo systems . The best one being Maximum Boost by Corky Bell ,it covers about every thing a novice need to learn to spend money...I was surprised that my 1000 Apex motor at 10300 rpm's has about the same flow of a 302 ford
    Re: ZX1400 CFM
    Jan 2009
    Australia, Canberra
    I have gone high hopefully it is sufficient enough tho 🤞
    Cheers for the info everyone.
    I will keep you posted on the result.
  1. Zx1400 custom short course buggy build
    By NFG in forum Projects in Progress
    Last Post: 03-06-2019, 03:55 PM
  2. R1 out zx1400 in
    By TALON in forum Projects in Progress
    Last Post: 04-13-2016, 11:45 PM
