Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
    Re: R-1 engine cuts out
    some RTV in the sensor does wonders, I think I finally found the resistor that simulated it and got rid of the sensor all together.
    Mar 2015
    Sandy Oregon
    Does anyone know how to get rid of the blinking fuel light? It blinks 8 times then repeats.
    Quote Originally Posted by SVP View Post
    Sure that’s not a diagnostic code flash? Might want to see how the R1 reports them, as it could be a code that you need to chase.
    Mar 2015
    Sandy Oregon
    I think it's flashing because I'm not using the factory fuel pump. I'm not getting any codes on the dash.
    Ah. So it’s telling you that you’re out of fuel.
    Is the fuel level sender still in the system? If not you need to put a resistor across the harness plug where the level sender plugs in. I can check the resistor on my harness if you’d like (if I can find it) - went half way between what the sender reads for high and low and my dash reads a half full tank.
    Mar 2015
    Sandy Oregon
    There's a fuel level sender in the fuel cell I bought. I ran the wire to it and a ground wire to a self tapping screw that was on the sender. I believe its a 0-90 ohm sender. I just hooked up the wires not knowing if it would work or not. I'll have to put in a resistor if they're not compatible.
  1. radius cuts
    By navanjr in forum Badland Buggy Group
    Last Post: 07-28-2012, 09:35 AM
  2. MEGALODON -Cuts
    By Y.O.R in forum Megalodon
    Last Post: 06-26-2012, 02:21 AM
  3. how to avoid miter cuts...
    By RoosterBooster in forum How To Do It
    Last Post: 05-27-2010, 02:55 PM
  4. making fish mouth cuts on tubing
    By wyattboche in forum Frame
    Last Post: 07-28-2009, 05:03 PM
  5. Handy tool for fishmouth cuts
    By bikelomen in forum Shop Talk
    Last Post: 05-21-2006, 09:31 PM
