Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
    4A032 Military Gas Engine (12-15 HP) for off-road buggie?
    Bit of an oddball engine. I have a couple of NOS 4-cylinder, 32 cu. in. Military gas engines (Model 4A032) (see: http://saturnsurplus.com/engine/engine.htm) that I had purchased 25 years ago to use in an off-road cart/buggy. Lots of things happened and I never got around to completing the build; but I still have the engines and various other parts. Thought I'd ask if anyone has ever used one of these on a buggy (or go kart) and if so, how it worked out. With an updated carburetor and few exhaust fixes, these should put out 12-15 HP although 'officially' military rated at 6 HP.
    Or ... should I just shelf these things and get a real engine
    I had originally started building a Kanoffroad RS (old design) buggy which was single seat. No info available on these anywhere anymore. I'm mostly just interested in a moderate speed off road vehicle (single or double seat) that can be built by a semi-newbie, so any thoughts on a suitable design would be appreciated.
    Re: 4A032 Military Gas Engine (12-15 HP) for off-road buggie?
    Sep 2014
    West Palm Beach FL
    I could be wrong, but I think the GY6 style engine in most of the chna buggies are only about 10 or 12 hp. What does that thing weigh?
    Quote Originally Posted by LIDUNO View Post
    Weight is about 63 lbs.
    Sep 2014
    West Palm Beach FL
    I would run it.
    Sep 2014
    West Palm Beach FL
    As long as the shaft will work with available cvt clutches
    Blog Entries
    1
    I would look the fan over real good. Those were genset engines made to run 3600RPM. Going more than that may risk exploding the fan. VW's had similar issues, we used to just fuse the blades in with a TIG and no rod so they didn't need rebalancing.
    6-1CR? Needs a turbo.
    I have a 1" keyed shaft that bolts on, which should work with a cvt.
    Sep 2014
    West Palm Beach FL
    I would be interested in seeing that bolt on shaft, and the back side of the engine. I'm a little concerned the bolt on shaft may be designed just to deal with the forces of lets say, spinning a pump, or a generator. The cvt is going to introduce force in a specific direction, it's kind of like pulling the crankshaft sideways.
    I don't know of anyone putting a turbo on one of these. I have seen that shaving the cylinder heads has been done to increase the compression. Would not be a big deal to shave off 0.05 or so which bumps the pressure up 15-20 psi.
    Here are a couple of pictures showing the shaft and mounting. I forget the bolt size at this point.
    Back side of engine
  1. Sand rail looking mud buggie
    By ces448 in forum Projects in Progress
    Last Post: 01-16-2015, 05:35 PM
  2. Tandem buggy gone military?
    By JGSturbo in forum Frame
    Last Post: 05-23-2014, 01:14 PM
  3. Combination on-road/off-road buggy: what are the downsides?
    By tenthousandfeet in forum MiniBuggy.net Lounge!
    Last Post: 05-09-2013, 09:06 PM
  4. 4x4 buggie
    By stillridin in forum Driveline
    Last Post: 06-27-2009, 12:14 PM
  5. Who makes the best buggie wheels?
    By bigfoot in forum Suspension - Wheels & Tires
    Last Post: 01-02-2009, 05:15 AM
