Results 1 to 10 of 11
    Hayabusa Oil Cooler Heat ExChanger
    Hi Guys Just designed and built a Heat Exchanger to cool the Oil in Busa plumbed into cooling system All sealed with O rings and I have double O rings on the inner cooling tubes Pressure tested the oil side to 300 psi and coolant side to 40 psi Have fitted it to the buggy and works much better than the usual oil to air coolers and less effort to fit too Not having to fit up oil cooler in air flow with a fan to cool it etc
    Re: Hayabusa Oil Cooler Heat ExChanger
    Sep 2008
    Allendale MI
    THAT is COOL!!
    Now the big question,
    How much for one?
    Justin
    Nowhere near the desert.
    $560 aussie dollars which is around $390 US
    Cooler in buggy
    Sorry images are sideways !!
    Nice!
    Thats slick!
    Very clean look I like it!
    Cheers guys it does clean it up a bit, plus i have used dash 10 fittings as dash 8 ( smaller fittings ) would be better with some 45 fittings too to neaten it up some more
    Very nice unit.....how much shipped to California 95688????
    Looking at Std shipping aust post is $55 aussie $$ and 5 working days to USA traceable with signature on arrival
  1. Hayabusa oil cooler delete?
    By hermie in forum Motor - Engine
    Last Post: 07-11-2018, 06:07 PM
  2. Hayabusa oil cooler ideas
    By Kuma in forum Motor - Engine
    Last Post: 10-07-2016, 10:42 AM
  3. Exhaust Heat + Shocks ???
    By Xbird in forum Suspension - Wheels & Tires
    Last Post: 10-10-2015, 11:26 PM
  4. Exhaust heat wrap
    By mal180 in forum How To Do It
    Last Post: 08-05-2013, 08:59 AM
  5. Chain Heat Testing
    By standfast in forum Driveline
    Last Post: 09-30-2009, 10:32 AM
