Results 1 to 6 of 6
    Fooling the atmospheric pressure sensor on a gen 1 busa
    Junior Member haycock's Avatar
    Mar 2010
    sacramento
    Im in the final stages of finishing by busa rail and while going through the wiring harness I realized that I'm missing the atmospheric pressure sensor. Everywhere is back ordered to buy a new one, so I wanted to fool the ecm to thinking its at 0-1000ft elevation so I can get this thing fired up and running until I can source a new sensor. If anyone could help me out I would appreciate it, thanks
    Re: Fooling the atmospheric pressure sensor on a gen 1 busa
    It should run without it, I believe, as long as you are just checking to see if it starts. Cam and crank sensors are critical (tip over sensor and kick stand switch need to be present/bypassed), but the rest just modify the map, so I wouldn't run it hard.
    Mar 2010
    sacramento
    Ok, thanks. Ill give it a shot once I finish up the harness.
    I would double check for ya, but I have mine all tore apart for upgrades. Let me know if ya need any help otherwise.
    Mar 2010
    sacramento
    Fired right up and it runs surprisingly well without that sensor and considering it hasnt ran since 2008. On to the next thing! finally getting close!
    IG:@Haycock_fab
    Glad to hear,
    I think it reverts to the rich side of the map, which probably isn't too far off if you are anywhere near sea level.
  1. rad fan switch sensor
    By Stomper in forum Cooling
    Last Post: 10-14-2013, 08:46 PM
  2. TO sensor
    By lessifer in forum Motor - Engine
    Last Post: 08-08-2010, 06:32 PM
  3. hayabusa tip over sensor
    By 455bird in forum Controls and electrical
    Last Post: 05-24-2009, 09:02 PM
  4. Fuel Pressure Regualtor on a busa??
    By doublej in forum Motor - Engine
    Last Post: 05-14-2009, 12:11 AM
  5. Busa oil pressure
    By arrowhead in forum Motor - Engine
    Last Post: 08-05-2008, 02:18 PM
