Thread: 13 hp Honda
Results 1 to 4 of 4
    13 hp Honda
    Feb 2009
    Baton Rouge area
    Hey guys, i posted this question on the facebook group, but figured i would post it here too.
    Basically, i am wondering if a 13 hp honda will be enough motor for my sons two seater. I want torque with a top speed of 20mph. With the clutch setup and fnr box... it is actually cheaper than just the GX630 motor, which is my other choice. The gx630 is what i have in my single seater. I dont think he is anywhere near ready for that though.
    Re: 13 hp Honda
    A 13 hp engine should work fine for the speed and torque that you're looking for. If he needs more horsepower later, there's a few mods that will kick it up to 20+ horsepower without too much trouble.
    I don't know if you've looked at clutches, but you want to go with a Comet 40 clutch setup at a minimum. The 30 series clutches don't work well above 8 hp, in my opinion. If you can afford it, a set of Comet 780 series clutches would be even better. If you upgraded the engine to more horsepower, the clutches would handle it with ease.
    Re: 13 hp Honda
    Feb 2009
    Baton Rouge area
    Thanks for the feedback darwin. Good info on the clutches as well.. not sure if i am going to use the same i have on mine or not(cvtech from protodie).
    Re: 13 hp Honda
    Mar 2015
    Yettem California
    The 13 hp will be good , I run a couple and I put one on a friends spider box, worked good for the youngsters tootling around
  1. Honda 600
    By pjohnson66 in forum For Sale
    Last Post: 04-02-2012, 05:04 PM
  2. Honda 550 Shafty
    By meatface in forum Projects in Progress
    Last Post: 12-22-2011, 08:20 AM
  3. Honda Fl 350
    By imported_bumpjumper in forum Motor - Engine
    Last Post: 08-09-2010, 01:04 PM
  4. Help with Honda Odessey 250
    By gtreasur in forum Honda's Pilot & Odyssey
    Last Post: 03-18-2010, 09:35 PM
  5. Honda vfr 800 ?
    By panelbeater in forum Motor - Engine
    Last Post: 01-24-2007, 05:55 PM
