ok, so looking for guidance, how to plumb the regulator return line?
1) back to pump inlet,
2) back to pre-filter inlet
3) or to the top of the fuel tank?
this is for FI system with Bosch 044 pump
Results 1 to 5 of 5
12-11-2017 07:29 PM
12-11-2017 11:46 PM
It should be somewhere where air can escape, and were you can sink some heat. Back to the fuel pump will heat the fuel considerably, unless it is being used.
Back to the tank, whether top or bottom would be the best.
I would personally route it to the bottom of the tank, no need to drip and aerate it any more.
12-12-2017 12:07 AM
sounds good, I only have the option of returning to the top but I can use a bulkhead fitting and run a tube down near the bottom so it stays submerged.
- Join Date
- Jan 2016
- Location
- Ohio, which is a long way from the desert
- Posts
- 35
12-12-2017 12:52 PM
#3 - top of tank
Turbo oil return line?
By jaywebguy in forum Motor - EngineReplies: 3Last Post: 04-27-2017, 11:26 PM -
fuel return line ?
By jereme316 in forum Motor - EngineReplies: 6Last Post: 03-29-2015, 06:13 AM -
Busa fuel return line
By jjstime in forum Motor - EngineReplies: 10Last Post: 12-29-2012, 03:56 PM -
Aeromotive fuel regulator plumbing?
By TutTech in forum Motor - EngineReplies: 9Last Post: 08-11-2011, 09:41 AM -
fuel return line
By 455bird in forum Motor - EngineReplies: 4Last Post: 12-27-2007, 09:10 PM
