Thread: Turbo Busa
Results 1 to 9 of 9
    Turbo Busa
    Jan 2015
    Norco, CA
    Okay, I am no expert on the subject, hoping to get some input, here is a little something I have heard, is it true?
    A friend of mine has a turbo car, Tom Pro, with a gen 1 Busa, he was telling me that the ECU has the stock tune and that all of the fuelling for the boost is done with the pressure adjusting fuel regulator, manifold pressure goes to the reference port on the regulator so that for each additional PSI boost the fuel pressure is increased by the same pressure.
    Re: Turbo Busa
    Depends on how much boost,
    Yes, this could be true with low boost, and no regards to adjusting your timing. Usually people run a custom map with the pressure regulator to get it a lot closer. You will need to tune sensitivity of the regulator as well, it isn't going to be pound for pound.
    There seem to be a lot of kits out there that get around 225hp without much hassle. Sounds like they are running 80-90 psi at the injectors at full boost, but didn't say what pressure that was at.
    Re: Turbo Busa
    Senior Member Akpilot's Avatar
    Anchorage Alaska
    Kuma
    Yes that is true you need to add fuel pressure as boost goes up but you also need add fuel with the injectors. I'm using a Power Commander to modify the stock fuel map, so when no boost your on the stock map but with each 1lb of boost you add fuel to the map.
    Ak
    Re: Turbo Busa
    Jan 2015
    Norco, CA
    I was under the impression that adding more pressure to the injectors was the same as adding more fuel flow. I guess as plk said not really enough and I hadn't given any thought to the timing issue. Guess if I do step up to turbo I'll be doing a lot more research.
    Re: Turbo Busa
    Apr 2015
    UK
    Not enough, flow will only go up by the root of the pressure change.
    Re: Turbo Busa
    You can get regulators that increase the pressure 2-1 or more, like up to 6-1 if your fuel pump will push it.
    Re: Turbo Busa
    Yeah, they have some that are pseudo adjustable, using a diaphragm and a bleed screw to get the right gain. A lot of kits aim for the square in pressure rise, 6lbs of air takes 36 lbs more fuel, etc.
    Re: Turbo Busa
    Jan 2015
    Norco, CA
    so sounds to me after being on suzukihayabuse.org forum that you use a high pressure pump like a walbro, a 1:1 fuel regulator which does some compensation for boost and then a FMU, at 6:1 to get up in the 90 psi range, I imagine some mapping mods would also be needed maybe through the power commander as AK said.
    I believe at least on a gen 1 anything more than about 8 pounds of boost and you would need to get bigger injectors.
    Re: Turbo Busa
    Sep 2008
    Allendale MI
    Check these guys out. I have heard a lot of good feedback from their products.
    http://www.bazzaz.net/index.php/fuel...ntrol-overview
    Justin
    Nowhere near the desert.
  1. st4 turbo busa
    By ausj in forum Projects in Progress
    Last Post: 02-06-2013, 01:46 AM
  2. Turbo Busa question?
    By steelerman in forum MiniBuggy.net Lounge!
    Last Post: 09-13-2011, 12:19 AM
  3. Which oil do you use in? Turbo Busa's
    By DuneMe in forum Motor - Engine
    Last Post: 01-17-2007, 08:20 PM
  4. turbo busa and jackshaft
    By masterfabr in forum Driveline
    Last Post: 08-24-2006, 09:28 PM
