Results 1 to 10 of 16
    New Yamaha turbo sled engine
    Senior Member opsled's Avatar
    May 2007
    Burlington Wi
    Don't get on here much anymore so I don't know if this has been talked about yet.
    Yamaha has a new turbo sled engine based off the 3 cylinder EFI 998cc sled engine. It's done to Yamaha standards so it should be a winner. Time will tell.
    http://www.amsnow.com/news/dyno-test...nder-dyno-test
    Thought some might be interested.
    opsled
    I reserve the right to change my mind if someone can prove to me it needs replacing.
    Sarcasim is my weapon of choice.
    Re: New Yamaha turbo sled engine
    Jun 2015
    Texas Panhandle
    Impressive horsepower. Less than impressive torque. And what's with showing only 2700rpm of the graph? Gutless on the bottom?
    Actually, that is a very impressive torque curve. Super flat all the way to the top. That thing should be a fun ride. If it makes 204HP in factory form, I'm sure a little ECU tweeking could produce quite a bit more.
    Jun 2015
    Texas Panhandle
    I like that it's flat, but I'm still skeptical of it when they only show such a small portion of the RPM range. I'm also curious why power is dropping off at 9000rpm on a 14,000rpm engine.
    I mean I'm not saying it's going to be a bad, boring engine...that's a lot of horsepower and a lot of torque...but, having dealt with a lot of boosted R1's that make more power on very mild builds...I guess I just had my expectations in the wrong place.
    Wow - that's going to be a killer unit.
    Oct 2009
    [QUOTE=makenzie71;315950]I like that it's flat, but I'm still skeptical of it when they only show such a small portion of the RPM range. I'm also curious why power is dropping off at 9000rpm on a 14,000rpm engine.
    Its not a 14g motor in sled form . A CVT at 14000 rpms would do some damage prob blow the belt or clutch high 8's is about where ya want a CVT to turn and this new yami is direct off thr PTO not reducted like the Apex
    May 2007
    Burlington Wi
    These 3 cylinder sled engines were ground up built to run a CVT (in a sled) unlike the 4 cylinder and Phazer twin. Those had there base in design come from the cycle world.
    The 3 cylinder is not designed to run higher than 9000 rpms and that's why it falls off above that #. Dynotech does most of the trusted unbiased dyno work for all sled engines. Factories use them, magazines use them and so does the private sector when trying to prove real dyno #'s. They are proven/trusted. Most stock sled engines work in the 6 to 9000 rpm range so they often only report in that range. It has nothing to do with hiding what is below 6500 rpms.
    Top HP #'s were also not their goal. I'm sure that if the goal was to beat the private sector's boosted #'s on any level they would not have much trouble doing so.
    opsled
    This is a motor with a warranty, not an aftermarket all out tune. That is why I think that there is a lot more to be had in the tune. The limiting factor will probably be injector flow.
    Good to hear from you OP.
    Not impressed by the torque? 125 ft lbs out of a 1000 is damn impressive. That is well over a stock busa.
    1000cc road bikes may make more power, but they are also spinning around 14k nowadays. Having over 120 ft lbs on that wide of a band would be awesome for the dunes.
    Btw, good hearing from you opsled, been a while since we've seen you around. This motor brought up a lot of attention from the wildcat crowd. It would be awesome to see in a wider version of the yxz in coming years.
  1. Wiring for Yamaha RX1 sled motor
    By stinkybutt in forum Motor - Engine
    Last Post: 10-25-2011, 10:27 AM
  2. Yamaha sled motors.
    By bdkw1 in forum Motor - Engine
    Last Post: 01-18-2010, 09:17 PM
  3. 05 Yamaha RX1 sled GOOD DONOR?
    By wingman in forum Motor - Engine
    Last Post: 10-22-2008, 04:00 PM
  4. Yamaha CVT turbo speed run
    By opsled in forum MiniBuggy.net Lounge!
    Last Post: 03-18-2008, 09:13 AM
  5. sled engine VS motor bike engine
    By hummerman in forum Motor - Engine
    Last Post: 08-28-2007, 06:28 PM
