Results 1 to 5 of 5
    Stand alone ECU options
    Senior Member fns's Avatar
    Apr 2012
    phoenix az
    Need ECU options/suggestions. I have put together Haltech setups on Rx7, 240sx, and a vw buggy. I have also used several powercommanders...I am looking for a setup up for my 2008 hayabusa buggy. Turbo charged running about 20lbs of boost and a quick shift setup.. I am thinking it would just be easier to get "Power commander: v-pti, Secondary fuel controller, quick shifter and ignition modul" They all daisy chain together.
    Any other recommendations or setups you suggest. I want it to be clean and right. (I do not mind paying for something that works)
    Re: Stand alone ECU options
    I use Woolich Racings software to reprogram my factory 2008 Hayabusa ECU . They have a forum that can guide you thru the boosted setup . This software also has a very easy to use auto tune feature that is very accurate . Another option is to talk to Kelly at KMS performance in Pheonix he has a neat way of fueling boosted engines . I am using his secondary fuel system on my turboed Canam Maverick, Kelly got me 200hp out of my maverick. Personally I think Kelly would be a good contact ( and he is local to you) he has Dyno tuned thousands of motors thru the years.
    The gen 2 hayabusa ecu will support a boost sensor as well, and would be a clean setup.
    Apr 2012
    phoenix az
    Kelly is a great guy and a wealth of knowledge. He actually is one of our dealers for the seats we manufacture. The seat shop is only about 2 blocks from him. I will go swing by and talk to him next week.
  1. options and opinions
    By Wheels in forum Motor - Engine
    Last Post: 10-02-2013, 06:03 AM
  2. Paddle tire options for single seater
    By NinjaRaptor in forum Suspension - Wheels & Tires
    Last Post: 09-18-2013, 08:44 AM
  3. ST4 Build with Options
    By smartbuggy in forum ST4
    Last Post: 07-30-2012, 04:26 PM
  4. Fuel pump options
    By fatal-exception in forum Motor - Engine
    Last Post: 05-29-2012, 02:47 PM
  5. 70-75" WB Side by Side Options
    By LCAC_Man in forum MiniBuggy.net Lounge!
    Last Post: 11-22-2011, 02:54 PM
