Once it runs even just for a few seconds it will fire back up as soon as I hit the starter button. But the 1st start of the day it turns over alot before it starts. I even have to give it a little gas...any ideas where to start to fix this? The harness & computer were sent to Peter D. Motorsports in Phoenix, AZ. Just not sure if the computer was flashed or if this is normal thing for it to do...
Results 1 to 10 of 15
- Join Date
- Nov 2007
- Location
- Yuma, AZ
- Posts
- 215
07-08-2013 01:13 PM
- Join Date
- Sep 2009
- Location
- 220 miles east of Glamis>>>Aka North Phoenix Az
- Posts
- 3,653
07-08-2013 01:38 PM
It sounds like a fuel pressure issue. See once u start it the fuel pressure is up.
So if the cranking of the motor takes a few. Then starts the pressure is good. So Turing it off and restarting would have good pressure. Make sence.
I would see if u can run a guage on the fuel line to monitor pressure.
- Join Date
- Dec 2006
- Location
- NW Georgia
- Posts
- 2,572
07-08-2013 03:27 PM
If fuel then cycle key 2-3 times should prime. No lights?
07-08-2013 03:31 PM
Chikin is on the right track, on the first start you should hear the pump running as soon as you power up the ignition circuit prior to hitting the start button, it sounds like the pump is not getting power until you energize the starter. So it has to prime (build pressure) and feed the injectors at the same time.
- Join Date
- Nov 2007
- Location
- Yuma, AZ
- Posts
- 215
07-08-2013 04:22 PM
No lights. No bike console. The pump is running at ignition. Now I am using the factory Polaris RZR fuel pump. It puts out 40psi when I tested it. I do have a fitting and gauge I will put in line to see what running pressure is. I was thinking I needed to put a high pressure pump & regulator on it but was trying to get away with using my factory RZR pump. Yes I put a GSXR1000 in my RZR..lol..
- Join Date
- Sep 2009
- Location
- Posts
- 3,653
07-08-2013 06:34 PM
Well there is a few Inline fuel pumps and that's what I use. It takes maybe 2-4 seconds to pressure the line.
I have A half inch line too so ur results may be quicker. But my engine (Honda blackbird 1100). I also have a return line. So the over pressure flows back to the tank.
This is how I could guess about fuel issues but would restart right back up once it was running.
I also do no run a stock fuel pressure regulator. So when I was also playing with pressures. Well I got flames out the exhaust and fouled out plugs. This is why I mentioned the inline guage to show what the fuel rail had.
- Join Date
- Nov 2007
- Location
- Yuma, AZ
- Posts
- 215
10-06-2013 08:32 AM
Ok...I removed the intank pump. Installed a pickup tube in tank of replace of the pump. I installed a Mallory #2225 pump & a pressure regulator set @ 50 psi. Ran the return line back to tank. It does start a little faster than before. The fuel pump does come on at ignition for a few seconds as its supposed to. But it still seems to crank over for a few seconds too long on the first start of the day & it doesnt bring the idle up for cold start.. Watching videos of others starting up they seem to go into a high idle for a little bit till it warms up... ??? Here is a pic for your enjoyment.
- Join Date
- May 2005
- Location
- San Diego
- Posts
- 382
10-09-2013 04:28 AM
I have a 04 GSXR1300 powered car and a 05 GSXR600 powered car. The busa motor has a fuel inlet line to the fuel rail and a line off of that rail that goes to the regulator so the injectors always see fresh fuel. The 600 powered car has no provision for a fuel line off the rail and the rail and line bleeds off the pressure so the inital start is fine, then it dies due to no fuel, then it fires back up, burbles until the air is gone and from then on it is fine. I suspect that you have a similar issue, air in the lines on initial start.
- Join Date
- Nov 2007
- Location
- Yuma, AZ
- Posts
- 215
12-04-2013 02:56 PM
I just bought a sand car with a 02 GSXR1000 and it fires right up at the hit of the start button. I had both rides next to each other sitting all night. In the mornings the 04 was very hard to get started and the 02 fired right up. I called Peter D Motorsports and they think because the plug is missing for the head coolant temp that it doesnt know to give a cold start. Makes sense to me. But now the problem is finding a plug. It was on the harness when I sent it in but I quess it got eleminated for some reason. So either I have to find the wires that go it and solder some wires onto sensor or get another harness & send it in to be modified....???? any one happen to have the plug for the coolant sensor for a 04 GSXR1000????
- Join Date
- Sep 2006
- Location
- Groves, Texas
- Posts
- 999
12-06-2013 08:19 PM
Get hold of the people that did your harness and ask them to send it to you, it belonged to you in the first place didn't it??
Sandrail build tips, tricks, and stuff learned the hard way.
By yoshi in forum Shop TalkReplies: 110Last Post: 07-10-2013, 08:10 PM -
FL250 New Guy with some questions-->ready to start a rebuild
By jstackaw in forum Honda's Pilot & OdysseyReplies: 6Last Post: 07-24-2011, 01:58 PM -
Busa motor hard to start
By bigrock in forum Motor - EngineReplies: 5Last Post: 08-02-2010, 01:09 AM -
new parts still no start
By cupcake in forum Honda's Pilot & OdysseyReplies: 23Last Post: 08-19-2009, 05:45 PM -
newbee ready to start building R16 shotgun
By powersmiths in forum MiniBuggy.net Lounge!Replies: 9Last Post: 04-20-2007, 07:00 AM
