Thread: Compression
Results 1 to 10 of 11
    Compression
    Senior Member bamabuggy's Avatar
    Feb 2009
    bham
    Hey everyone have a piranha with a 700 Yamaha fazer been sitten up this winter every year have to change the plugs just to get it running so i changed the plugs just can't get it to start. Removed the carbs and check them they looked ok was wondering what the compression is for this motor ?
    Re: Compression
    Senior Member fabdaddy55's Avatar
    Dec 2010
    Port Orchard Wa.
    120 to 150 to run good
    below 110 get hard to start
    my 580 fi has 130 and screams
    Re: Compression
    Feb 2009
    bham
    Thank you fabdaddy55 will check tonight can this motor be rebuilt ? Or is it better to replace
    Re: Compression
    Dec 2010
    Port Orchard Wa.
    you also need to do a crank seal test (google it )and yes you can rebuild it. The top end is simple. The crank bearings and seals ,alittle more involved but still pretty simple.Theres just not a whole lot to a 2smoke motor. after the comp. test and crank seal test, you will know how much to do. If the comp. is below 120 you may be able to just do a good hone job to remove glazing from the cyl. walls and put new rings on the original pistons and get the comp back up some. If the comp. is way low, have the cyl bored out and get oversized pistons and rings. If the motor has lots of miles on it ,check out the crank bearings . You dont want to beef up the top end if your bottom end is tired . Good luck with comp test
    Re: Compression
    Feb 2009
    bham
    It's a four stroke Yamaha fazer bike motor sorry not a two stoke sorry if I didn't describe it well . It has four cilinders what would be compression for this motor . Are you talking about a sled motor would like one of those I here they go!!!
    Re: Compression
    Dec 2010
    Port Orchard Wa.
    Woops! Sorry Bama. My bad
    dont know anything about that motor.
    last time I was around a phaser it was 2stroke
    good luck
    Re: Compression
    Feb 2009
    bham
    It's cool well get it fingered out every year it gets harder to start Would like to have fuel injected motor any way so will looking for one
    Re: Compression
    Feb 2009
    bham
    Hey guys took the motors top end off found that number one and four was pitted bad where the bike had set up before I got it .went by a machine shop there going to look at it and see how bad it is . also check the head out and see if it's ok .
    Re: Compression
    Feb 2009
    bham
    Here's some pics of the cylinders and the head After the shop made it flat again .. . .
    Re: Compression
    Feb 2007
    NW Washington
    Looks like you need to steel sleeve or renickasel (sp) the cylinder.
    I like a steel sleeve. You are into the AL cyl. wall. Wont last much longer..
    Al cyl walls. Think Vega... Are you that old??
    Can you get new cyl.???
  1. How a Shock Works
    Last Post: 05-31-2012, 10:09 AM
  2. Setting Bump? Do you calculate the compression of the tire?
    By rgvkid in forum Suspension - Wheels & Tires
    Last Post: 12-05-2010, 12:11 AM
  3. compression test results.
    By ruthlessxbeastx in forum Honda's Pilot & Odyssey
    Last Post: 12-10-2009, 07:53 PM
  4. limiting compression on fox 2.0
    By andy777bmx in forum Suspension - Wheels & Tires
    Last Post: 12-09-2009, 06:02 PM
  5. spring rate
    By enroffroad in forum Suspension - Wheels & Tires
    Last Post: 11-29-2007, 04:40 PM
