Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
    Re: Adding a oil cooler to Arctic Cat 660 turbo engine
    Nov 2007
    Fort Worth Texas
    Bill or Don if you need more pictures let me know.
    Feb 2007
    NW Washington
    I would look for a better hose than radiator hose. (parker-push lock) Not made to run oil..
    It will start to leak oil.( or weep oil ) There are better oil coolers out there than what you have, could add a fan too, or go with a oil to water cooler. http://www.ftzrachttp://www.ftzracin.../600cooler.htm You have a 2 core radiator should work....
    Nov 2007
    Fort Worth Texas
    About a week after I installed the oil cooler the radiator hose I used for oil lines, started to let oil eat its way through the hose. I am replacing the hose with hose made for oil lines.
    Oct 2009
    Quote Originally Posted by stress View Post
    Thats funny , I learned that the hard way when I did my engine swap I went to Carquest and bought oil line hose . And the dont -give-A-shit parts person sold me radiator hose . The stuff swelled up and one line game off. I caught it in time so no damage done , But I had to change out all the lines. Mr.Bill at Carquest was nice enough to give me the right hose N/C ..
    Petoskey, Michigan
    My buddies Desert Dog Coyote also has the 660t Artic Cat turbo engine in it. After seeing this thread I looked at his machine a little and was thinking what would it take to just cool the coolant more before it goes into the chamber under the filter.
    Nov 2007
    Fort Worth Texas
    I added a oil cooler because I have the biggest radiator I can fit in roll cage, my radiator water temperature is 225 F during hard running. I wanted to get the radiator water temperature lower, but this would require a bigger radiator, I have no room for this. So I was thinking added the oil cooler would help lower the water temperature. So I did not look at trying to get more water flow into the water chamber below the oil filter. The water line coming off water chamber goes to the turbo and flows through the turbo. So that would require modifying the turbo.
    Nov 2007
    Fort Worth Texas
    I have upgraded my tube style oil cooler to a radiator style oil cooler that works lot better.
    https://www.minibuggy.net/forum/motor...tml#post267541
  1. Oil cooler options for CBR600RR 08 engine
    By saulo6 in forum Cooling
    Last Post: 07-28-2011, 10:13 AM
  2. Why is Oil So Critical to My Engine?
    By installers in forum Cooling
    Last Post: 03-06-2011, 10:04 AM
  3. Arctic Cat T660 engine mod
    Last Post: 07-12-2010, 08:49 PM
  4. Arctic Cat 650cc twin liquid cooled engine value??
    By jwcarguy in forum Motor - Engine
    Last Post: 10-01-2009, 04:12 PM
  5. Diesel Engine Project
    By DesertDrifter in forum Motor - Engine
    Last Post: 07-03-2008, 02:31 PM
