Question with my bike engine the fuel rails dead end into the motor..
I have only plumbed the fuel regulator after the rails on big engines... so the regulator has to go before the rails.
So I didn't see in the instructions how to do this.
http://aeromotiveinc.com/wp-content/...9/12/13101.pdf
I am sure many of you have ran into this situation so what is the best way to eithe plumb the regulator or run the the fuel set up.
Also do you guys run a line back to your tanks if your running a safety fuel cell and what is the best way to do that.
Run back into the vent side and do you do a T fitting dumping back in that side with the breather or without the breather? Do you turn it into a sealed system? Or leave it to vent? Venting helps fuel faster etc. but if the engine needs to be sealed for EFI etc. would be nice to know.
Any other thoughts would be great.
I have a bosch fuel filter and then a bosch fuel pump running in line. Then looks like I have to do my regulator then into my fuel rails.
I have a 600cc gsxr 2005
Thanks.
Results 1 to 10 of 10
08-06-2011 01:31 PM
08-06-2011 01:55 PM
I have never tied the return line into the breather, not sure if it would try to push fuel out the breather or not if the breather was high enough.....?
08-06-2011 01:56 PM
I forgot to draw the breather line in that diagram, but there should be one.........
08-06-2011 02:02 PM
The breather starts off my tank goes up to the roof, then across and then down the other side of the car.. I would tee into the very bottom at the fitting comming off my fuel cell.. then the tee going up would then be the breather.
So all the fuel has to do is drop down into the tank.. so it can't back up to the roof..
We shut down when fueling so it will breath out normally. Then fire up and off we go.
Dang I do see a big problem with the Check valve in the tank being down in it and fuel coming back in ontop of it.... IF I am ever upside down I better shut off my buggy quick.. or put another 1 way valve after this.. so the pump wont run fuel out the breather.. Ok I have some work to do there..
Should work.. but just wanted input on this... with it being a metal outer and plastic inner bladder it would be tough not impossible just tough to add another fitting at this point.
Ok.. so let me see if I can follow your diagram?
Your using the regulator to relieve pressure that builds back from the rails... the regulator releases the extra psi from the pump by being Tee'd in with the rails.
So working like a flood gate.
Ok. Makes since. I knew you guys had a perfect way to do this.
Thanks a lot Yoshi I appreciate that diagram very cool.
ThanksLast edited by TutTech; 08-06-2011 at 02:06 PM.
08-06-2011 02:08 PM
Posted at the same time.. Ok no worries...
Am I over thinking this.. can't the fuel return go back to the fuel pick up line? Tee into it just at the tank.Last edited by TutTech; 08-06-2011 at 02:12 PM.
08-06-2011 02:44 PM
08-06-2011 02:46 PM
08-06-2011 03:48 PM
Ya I was thinking something like that might happen.. dang..
Setting up for another return inlet is going to be a bummer at this point.. shoot.
Ok..
Hey thanks a lot Yoshi.
08-08-2011 03:07 PM
I ran my fuel return to a baffled section of tank away from the tank outlet. The return is actually adjacent but a tube inside the tank moves the return to a higher chamber.
I wanted to reduce turbulence and heat so the fuel coming to the engine would not be warmed by returned fuel from the engine.
08-11-2011 09:41 AM
hmm.. good point as well
Thanks Gene didn't even think of something like that.
Ok thanks guys
Formula Desert Lites
By pride_in_motion in forum Class DevelopmentReplies: 53Last Post: 07-22-2013, 10:22 PM -
Doubledown and hair pulling fuel pressure puzzles
By amergin in forum MiniBuggy.net Lounge!Replies: 17Last Post: 03-29-2012, 03:46 PM -
Fuel Cell And Fuel Delivery Question??
By GR8WHITE in forum Motor - EngineReplies: 20Last Post: 01-31-2009, 03:09 PM -
why do I have positive pressure in my fuel tank?
By Damien in forum Motor - EngineReplies: 12Last Post: 02-08-2008, 07:30 PM -
General Rules and Information for our Database
By K-fab in forum Class DevelopmentReplies: 12Last Post: 09-19-2007, 08:27 PM
