Results 1 to 10 of 14
    Who runs an oil cooler on their Busa?
    I am plugging along on my Busa ELTORO tryin to get it done by Memorial Day, and they guy I purchased it from gave me an aftermarket Oil Cooler. I notice that King sells blank offs....So should I run the Cooler or not. The Radiator I have is off a Honda, and it looks to have a built in Tranny cooler (it has two brass nipples on the bottom of it), so if I need to run the cooler, Can I just use that????
    Re: Who runs an oil cooler on their Busa?
    Off of the top of my head I will say no, the pressures are different. I do not think that the tank in the Honda radiator would last. I do run an oil cooler on my rail. I installed a small fan but I discovered that the busas' alternator just doesn't put out enough wattage to run everything AND charge the battery. I solved this by wiring the oil cooler fan into the water fan relay.
    Quote Originally Posted by Glamisman View Post
    I solved it by running the oil cooler under the radiator and piggy backing off the radiator fan...
    www.SinisterSandSports.com
    918-521-3736
    Feb 2007
    you can't run the cooler through the rad! if you open those up, rad fluid pours out. So you'd be pumping radiator fluid into your trans. Yoshi's set us is the best way. You can pick up oil coolers pretty cheap
    I have run with and with out one.....if you dont run one you will have hotter water temps.
    Personally I wouldnt run w/o one unless its only for a short period of time.
    And like said before dont use the one built internally into the radiator.
    Blog Entries
    1
    The built in tranny coolers also don't flow enough to support an engine.
    Petoskey, Michigan
    Quote Originally Posted by greasemnky View Post
    I agree a factory stock radiator automatic tranny cooler cannot flow much oil. In the cars they flow just enough fluid to try to remove heat.
    But I don't understand what greasemnky said above. If radiator fluid pours out the tranny cooling holes its due to the units been punctured or failed internally somehow.
    Quote Originally Posted by nutz4sand View Post
    I don't think he understood that there is 2 separate chambers..
    918-521-3736
    Mine is piggybacked like Yoshi's.
    Does your H2O radiator have enough cooling capacity? Have you read Standfast's thread?
    Ok, I will run it. Its about a third the size of yosi's. But its set up the same way, to piggy back (front) off the Rad and fan setup. I hope its got enough flow, I will check out that thread. I have heard of a couple guys running them.
    Will the rad fluid melt pvc fittings (ie to make a 90 degree bend) on the radiator hose? or should I use brass?
  1. Oil cooler in radiator
    By BSG in forum Cooling
    Last Post: 03-16-2013, 08:02 PM
  2. R1 vs. Busa
    By Andy_1972 in forum Motor - Engine
    Last Post: 01-09-2011, 07:16 PM
  3. Oil cooler on gsxr600?
    By rahlberg13 in forum Cooling
    Last Post: 01-27-2009, 10:13 AM
  4. project busa powered side by side....
    Last Post: 05-20-2008, 09:49 PM
  5. How much hp can YOU get out of a busa?
    By P-Dog in forum MiniBuggy.net Lounge!
    Last Post: 02-24-2008, 01:09 PM
