Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    ** Need Pics Of Chain Idler / Tensioners
    ive searched chain tensioners and chain idlers and find no posts with pics. I HATE THAT. i am a picture orientated learner. i would love to see whats out there on your cars if the set up uses an idler or tensioner. i want to use my lower engine mounting plate for the tensioner plate with a slot for adjustability. i just need some pics to get some creative juices going. thanks
    You wanna start me up? Just open the choke and pull the cord. There's gonna be an earthquake and you're dancing on the fault line.
    Re: ** Need Pics Of Chain Idler / Tensioners
    Feb 2007
    Simple is better. Basiclly a lever with a sprocket on the end. And generally a bolt to adjust it. Don't get into fancy spring loaded tensioners, they tend to fail.
    That's what I have on the Rorty R82. I'd get a picture but it is in the trailer. Can get it in two weeks . . .
    Let's see what I got...
    I believe this was a sprocket machined out to have bearings pressed in. I think I got these pics off this site Vin.
    Off this thread.
    https://www.minibuggy.net/forum/drive...-sprocket.html
    Feb 2007
    is that adjustable? Looks more like a guide wheel.
    Shoot, I forget the site, but someone has them for the 520/530 chains with a bearing for like 10-15 bucks. Want to say grainger or something like that.
    Yeah, that is fixed (that is my setup). I would make a bunch of other holes if you wanted it to be adjustable.
    Here's a pict of how I did mine. I made the whole carrier adjustable, mainly b/c I didn't know if I'd have the room to make an independantly adjustable idler. I ended up making the right call.
    The whole carrier is pivoted on a hardened 1" rod. I can adjust it up or down using the two threded rod links. I also have the idler in there (basically to get the chain up and over part of the frame). it's actually just a bushing I machined out of delrin for the time being until I get a sprocket in there, but it's fixed.
    This isn't the ideal setup, the whole rear end was a redesign and I was kind of stuck with a lot already. But it works really well.
    Hope this helps spark some ideas.
    Senior Member Pacman's Avatar
    Jul 2007
    Mechanicsville, Virginia
    Quote Originally Posted by greasemnky View Post
    McMaster-Carr
    Here is one I built from Rorty plans.....sort of!
    Senior Member Gotted's Avatar
    Apr 2008
    Clarkston WA.
    I made mine from a 3inch polyurethane bushing with a sleeve and a bearing and some dome tube .Its a soled mount.
    Gotted, That 2nd pic looks like you're using a Banshee carrier with a street bike motor???? or does it just look like a Banshee rear carrier?
    Quote Originally Posted by Gotted View Post
  1. Doug Heim's Cuda Build
    By Doug Heim in forum Projects in Progress
    Last Post: 04-15-2016, 03:29 PM
  2. Idler sprocket for 520 chain
    By dlarryk1 in forum Driveline
    Last Post: 10-24-2011, 11:23 PM
  3. 530 chain maufacture for haybusa power minibuggy???
    By bngcustoms in forum MiniBuggy.net Lounge!
    Last Post: 12-23-2007, 10:30 AM
  4. Chain at 16000 rpm
    Last Post: 01-20-2007, 04:14 AM
  5. Chain driven trailing arm
    Last Post: 01-18-2007, 06:04 PM
