Few quick questions that should be simple to answer. I have a stock 2000 CBR 600 fuel pump to be used with a 2000 CBR 600 engine. Any idea which is the in and which is the out line on the pump? Also what is the little port black outlet on the top of the pump, does that need to be hooked up to anything, or is it a vent? If it is a vent should the pump be orientated so that tab is facing normal to the ground (upward)?
I also got what was called the fuel line regulator shown in the picture. I assume I should use this. Should I just put this in the line after the fuel pump? Or should I just not use it all together?
Also do I need a return line for the fuel pump to the tank, or just a straight fuel line to the engine. I would think no return line because it is the stock pump and it should have the right fuel flow already.
Thanks for your help!
Andy
Results 1 to 4 of 4
03-11-2009 03:32 PM
- Join Date
- Feb 2007
- Location
- Gilbert, AZ
- Posts
- 799
03-11-2009 06:32 PM
The line on the black cap is a drain as best I can figure. Although with the design of the pump, no fuel should ever be present in that area. It could be a drain for condensation. I'd face it downward.
The "fuel line regulator" is the petcock. It screws to the bottom of the stock gas tank. It lets you switch from on to off to reserve. It goes before the pump.
The pump is self regulated, there is no return line or additional pressure regulator.
I'll check the in and out when I get home.
03-12-2009 05:12 PM
Thanks for the info.
If I am using an aftermarket spun aluminum tank, is the petcock even necessary, or could I just run a line directly to the pump?
If you or anyone finds out what is the in/out, that would be a big help.
Thank you!
Andy-
- Join Date
- Feb 2007
- Location
- Gilbert, AZ
- Posts
- 799
03-12-2009 08:33 PM
In the second picture, the inlet is the one on the bottom.
The valve is not necessary, but nice if you need to do something with the pumps, line or filter.
I'd also put a filter before the pump and after the pump.
Finally I'd run some gas through the pump before you cut all the line and mount it, just to be sure the inlet/outlet info is correct. For some reson your black cap is 180° from mine.
Racing Cost & Information for each Class.
By TutTech in forum MiniBuggy.net Lounge!Replies: 12Last Post: 10-20-2020, 11:07 PM -
Doubledown and hair pulling fuel pressure puzzles
By amergin in forum MiniBuggy.net Lounge!Replies: 17Last Post: 03-29-2012, 03:46 PM -
Fuel Cell And Fuel Delivery Question??
By GR8WHITE in forum Motor - EngineReplies: 20Last Post: 01-31-2009, 03:09 PM -
any pics of stock fuel pump set ups how you are hooking them up
By huldahq in forum Motor - EngineReplies: 13Last Post: 01-30-2009, 07:00 PM -
General Rules and Information for our Database
By K-fab in forum Class DevelopmentReplies: 12Last Post: 09-19-2007, 08:27 PM
