Page 4 of 15 FirstFirst ... 2 3 4 5 6 14 ... LastLast
Results 31 to 40 of 143
    Re: Site Bug Reporting thread
    #31
    I hear you on that, I wish I had that old animation of the stick figure banging his head against the keyboard! Too funny.
    #32
    Search is not available for selection, used to be in the top menu bar. It used to take you to an option called Advanced Search, specify search attributes and find the information you are looking for a lot faster. None of the links in the thread tool bar work (Thread tools, Search this Thread, etc.
    #33
    OK, Ninja try this.
    Click the button you want, then move curser into open area and click again. Then go back and click the button.
    Oh and you should be on the main forum page, wont work from a thread.
    I am still using the default mode and everything works.
    However theyre are still some quirks.
    Like viewing a members stats page.Still have to find the name inn small text, large wont work.
    Heres what im using,
    #34
    Hey Bullnerd,
    Using the Default UI does work with the method you mentioned above. It looks like the focus policy of the mouse is not right.....but it does at least work and I can use the advanced search capability. The links on the main page work (Fusion64 UI), but the advanced search is no where to be found.
    #35
    Switch back to the Lustrous Fluid view. Looks like my guy's getting things in order.
    #36
    Yeah, focus policy, thats it !
    #37
    Pix in signatures not showing up - Yoshi is a perfect example
    Search and Quick Links not working in forums and sub forums
    Attached pix not showing up for some.
    Drop down menu not showing up when you click on member name
    #38
    Senior Member mmobley's Avatar
    Jan 2013
    Jefferson, Iowa
    Hi K Fab. Hey I have that build thread going "Time to man up..." and a friend that has been following said none of my pics show up starting on page 23. I suppose I should open a photobucket account. It would be a shame to think all of this documentation might be for nothing. Anyway, just wanted to make you aware of it. Thanks for all you do for the site.
    Mitch
    "You gotta keep on keepin' on"
    Joe Dirt
    #39
    thread tools not working in threads
    #40
    Kfab, lately when trying to post a comment on someone's thread it takes three or four tries to get it to go through wether on my iPhone, iPad or my pc.
