Results 1 to 6 of 6
    Honda CBR 954RR wiring???
    The Dalles, Oregon
    Hello, anyone out there know anything about wiring for a 03 Honda 954? got a complete bike with frontend damage, its got spark and will run if you add fuel by hand, but the injecters wont open, and the fuel pump won't run, we have by-passed the tip sensor, and can make the fuel pump operate with *12volt power, we have checked most of the relays fuel cut-off, ect. so if there's anyone out there that has some answers please share..............thanks
    Re: Honda CBR 954RR wiring???
    The Dalles, Orygun
    you should bought a busa!!!!!!!!!!!!!!!!!!!! HAHA!!!!!!!!!!!!!!! LOL
    Quote Originally Posted by Racerj404\";p=\"26391
    No one appreciates this...
    Anyways, On my GSXR, you cannot bypass the tip over. It has 65 milliohms of resistance to it, which the ecu needs to "see" it. There is also a switch for the kickstand. Make sure the bike is in neutral, and try to trace the fuel pump wires back. There is a relay or something that is stopping the fuel pump and injectors.
    The Dalles, Orygun
    IT was a joke, bulldogs engine is in my shop. But i asked a question about what turbo to use and at first everyone said you should have bought a busa or you should sell you 750 and buy a busa, that is where that joke came from.
    The Dalles, Oregon
    plkracer thanks for the input, I'll recheck the tip sensor.........
    Feb 2006
    Winder Georgia
    you can bypass the sensor, but you have to do it with a resistor...You will probbaly find it is the tip sensor holding you up, why did you bypass it anyhow, cant you set it upright and make it work?
