Results 1 to 7 of 7
    homemade bump steer guage
    Mar 2018
    Central Ohio
    I'm looking to build a bump steer gauge. Google search revealed a multitude of examples (homemade & manufactured). Has anyone ever made one ? If so, what have you found to work or not work.
    Thanks in advance.
    Re: homemade bump steer guage
    Never looked at one.
    Got any links?
    Bend-Tech Dragon Master
    Nov 2009
    Made one about 20 yrs ago with 2 small pieces of plywood and a couple hinges....but I can't remember the specifics.
    Nov 2009
    whatever you do, put it on rollers so things can settle and pivot freely.
    Mar 2018
    Central Ohio
    Got any links?
    Here are some that I found....https://www.google.com/search?q=bump...w=1517&bih=671
    Mar 2018
    Central Ohio
    Appreciate the picture & response(s). Nice set up you got there.
    Yeah...When I first started tinkering with the front end I noticed that the rake really moved the wheel(s) rearwards a couple of inches and 10" of travel. All the units I was seeing on-line had the floor unit stationary and most only had 3" travel in each direction. can't see them working for most off road suspensions.
  1. A-arm and bump steer.
    By T-man in forum Suspension - Wheels & Tires
    Last Post: 11-17-2015, 07:01 PM
  2. Bump Steer
    By Jan-Willem in forum Suspension - Wheels & Tires
    Last Post: 04-23-2015, 05:53 PM
  3. Bump Steer Problems
    By FullThrottleKTM in forum MiniBuggy.net Lounge!
    Last Post: 08-20-2012, 11:48 AM
  4. Bump steer cure.
    By SCEADU in forum Suspension - Wheels & Tires
    Last Post: 10-09-2011, 06:18 PM
  5. Bump Steer
    By KWiKSand in forum Suspension - Wheels & Tires
    Last Post: 09-11-2006, 04:24 PM
