Results 1 to 5 of 5
    Gonna build a garage.
    I'm looking for advice/suggestions on radiant heat for my soon to be garage.I'm shooting for 30'x50' 10' ceilings (in Central PA, so the winters get fairly cold). I don't have natural gas and currently heat my house with propane. I would like to eventually put a lift in, so at least half of the garage will be 6" slab.In the little research I've done to this point, it looks like $1 to $1.25 per sq ft is about what it will cost for insulation and the pex (and associated hardware). Does that sound about right?As for heating it, I am going back and forth between electric (maybe a water tank, or tankless heater) and propane boiler. Anyone have any thoughts, experiences or cautions on this?
    Re: Gonna build a garage.
    Senior Member Jerm's Avatar
    Dec 2013
    Ontario Canada
    I ran pex in my floor but I havn't hooked it up yet, you need insulation underneath so you don't lose heat into the ground. A few pictures of mine here:
    Jerm's Pole Barn Shop
    I left out the areas where the 4 post hoist sits, so its not sitting on the waterlines.
    Nice shop Jerm. Do you recall how much you had in the insulation and pex setup? What are your wall heights?
    Here's my pole building that I've been working on for a million years.
    Its a pioneer from PA.
    Bullnerds new shed.(Aus for garage)
    Id go higher than 10' if your getting a lift, Unless you do scissor trusses.
    No radiant floor here though. I have a gas radiant tube heater that will be ceiling mounted, is not installed yet.
    Good luck.
    I suggest going taller ceilings. My grandpa screwed me cutting all my posts off at 10ft (had them already at 16). I had to sell my 2 post lift and had to build an a frame that lives outside because the beam for my gantry was gonna be too low. At the time I got the 10x10 posts free or I woulda tried to go at least 18 or 20 tall.
  1. Gonna teach myself Shock Valving
    By rgvkid in forum Suspension - Wheels & Tires
    Last Post: 12-14-2013, 02:30 PM
  2. gonna build this, this week
    By jrpitdog in forum Shop Talk
    Last Post: 02-14-2011, 02:39 PM
  3. We're gonna need your truck a few more days...
    Last Post: 10-24-2010, 12:53 AM
  4. If your gonna roll down a hill...
    Last Post: 02-24-2010, 12:06 PM
  5. New guy gonna try the panther again
    By Will_lc8 in forum The Welcome Mat
    Last Post: 12-17-2007, 05:58 PM
