Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
    Re: yard kart/buggy help
    #21
    428 Has bigger roller diameter that wouldn't fit it also has a wider roller width. The bulk #41 isn't nearly as strong as a motorcycle chain. #41 has 2000lb tensile strength and 420 is 3700lb. If that isn't enough, then you will probably have to step up. 520 chain is 6100lb.
    #22
    After a couple of months off of the little buggy project, I finally got back on it. Mounted a simple 1 gallon fuel tank, cut up the stock exhaust header and made it into dual pipes and mufflers. Ordered a new axle sprocket and driver sprocket in #41 and installed a brand new #420 chain. Had a little twisting in the engine mount, so I welded it up and installed a neat little turn buckle brace that's adjustable. Had to steal the battery out of my 660r Raptor to put in it, but should get to play in the snow with it later today. Fingers are crossed that I've got most of the bugs worked out of it finally.
    #23
    Senior Member jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    Few pics of it in action would be mint if able.
  1. gs 500 kart/buggy
    By kawabug in forum Projects in Progress
    Last Post: 10-01-2012, 05:40 AM
  2. gs 500 buggy/kart finished
    By kawabug in forum Show off your toys in here!
    Last Post: 09-29-2012, 09:05 PM
  3. 250 xl kart/buggy
    Last Post: 12-09-2011, 04:56 PM
  4. junk yard dog
    By seancarole in forum Projects in Progress
    Last Post: 12-05-2010, 02:51 PM
  5. back yard fun fl400
    By adnoh in forum Honda's Pilot & Odyssey
    Last Post: 08-29-2009, 11:41 AM
