Results 1 to 10 of 16
    Accessing User Control Panel
    Go to any page other than the home page (after logging in)
    To to the very bottom left corner of the page and you'll see a little window that says
    -- Lustrous - Fluid
    Click on that and select the other option -- Fusion64
    That should change the way the site looks and in the upper left hand, there's a menu box with User CP at the very top. You should be able to work from there.
    I'll hopefully get things back in order soon enough.
    Re: Accessing User Control Panel
    It's not showing that option for me. You can click the Private Messages link and it will take you to the CP.
    Zach
    2003 Short Sand Car
    Turbo Yamaha R1
    King Coilovers
    Okay then...
    It would appear that it's an option that only the Admin could see. Amergin must have set it up that way.
    So I guess everyone should disregard for the moment.
    I may be able to head into the programming and make the site display with the other layout. I'll poke around in a bit and see.
    If the site suddenly looks really different, then I got it working!
    "That will be safe"...... Said no admin ever. Ha I'm only kidding!!!
    MiniRaptor
    Guest
    Okay, I have it setup and I can view it as this screen name (my stealth profile).
    Can anyone else see the little box in the bottom window now?
    Quote Originally Posted by MiniRaptor View Post
    I got it now.
    Ok, I see the link now and have access to the new menu on the left. That will work!
    Senior Member deaner's Avatar
    Sep 2011
    Northern Ohio
    Maybe I'm missing it, but is there a log-out "button" somewhere?
    Senior Member NoClue's Avatar
    Aug 2008
    Fullerton, CA
    Why would you want to log off? Lol...yeah, I noticed that too.
    Exclamation
    Quote Originally Posted by NoClue View Post
    Hey you do not need to log out. Scroll to the bottom of this page and look for this and click it.
  1. What have I gone and done???
    By K-fab in forum The UTV Area
    Last Post: 02-25-2016, 03:25 PM
  2. Shock mounting: upper or lower control arm?
    By UkraineTrain in forum Suspension - Wheels & Tires
    Last Post: 11-23-2009, 12:04 PM
  3. DIY engine control system build
    By rowycoracing in forum Controls and electrical
    Last Post: 12-12-2006, 08:36 PM
  4. GSXR Gauge Panel
    By KWiKSand in forum Controls and electrical
    Last Post: 02-06-2006, 01:21 AM
