Results 11 to 20 of 21
    Re: Need help with 1/2 scale truck
    Darwinpayne that would be great. Ill have to check but I think the rims I used were 10 inch. So shouldnt be any issue fitting
    Sent from my LM-V405 using Tapatalk
    Nice job!
    Nice job!
    Thanks
    Sep 2014
    West Palm Beach FL
    Blog Entries
    2
    Quote Originally Posted by ricky.wells33 View Post
    Considering the topic, the shirt is perfect..lol
    S.W. Michigan
    cool looking truck!
    I agree with previous posts
    one caliper on the rear will stop it
    1. I would run a 1/2" to 5/8" master cylinder,
    2. 8-10" dia rotor
    3. if the MC is low on the frame, try adding a 2 lb residual valve
    if still not good enough
    4. add a 4 piston caliper.
    I run 4 piston wilwood, part # 120-6818 caliper with brake pads 150-8850K on single rear brake buggies
    pricey though. A used motorcycle caliper should be able to do it too
    3. make sure you have enough throw / leverage on the pedal. depending on the pedal location, may have to go to a hanging pedal to increase leverage
    and bleed, bleed , bleed and re bleed the brakes good. tiny bit of air in the system can take away all your power
    Quote Originally Posted by ProtoDie View Post
    cool looking truck!
    2. 8-10" dia rotor
    http://www.nexgenoffroad.com/product-p/798520r3.htm
    Could something like that be used? And if so how do I match up calipers to it?
    Sorry for the delay. Work intervened. As I stated the hub is a standard go kart hub that you find on a lot of websites with a 4 on 4 inch bolt pattern. The spindle is a 3/4" grade 5 bolt that's welded to the spindle assembly. This design is borrowed from the Shredder II buggy plans.
    The front brakes are my own addition. The rotor is a 6" x 1/8" minilite with a 2" center hole. This makes it slide right onto the hub. If you're running 10" tires, you could go with a 7" rotor for more stopping power.
    I bought 3" and 2" bimetal hole saws and cut a donut ring out of 1/4" plate steel. Weld-on tabs would probably accomplish the same thing, but I thought the ring would make it easier to get everything perpendicular to the hub. Also, in hindsight, 3/16 plate steel or just tabs would have been sufficient. I drilled the mounting holes through the ring, using the hub and the rotor as the jig/mockup for drilling the holes.
    I cut a rectangular piece from plate steel as a bracket for mounting the caliper. I drilled a 3/4" hole for slipping the bracket onto the spindle. I slipped the rotor onto the hub, then figured out the distance and the hole spacing for mounting the caliper onto the bracket. the bracket needed a big notch in the end to clear the caliper. I fitted everything together to verify alignment, then I tack-welded the donut to the hub. The rest was just welding everything up.
    The pictures will probably explain the rest of the story. After I built the front hubs for 8" tires, I moved to 10" tires with a different bolt pattern. (Yes, everything looks rusty. A work in progress, I'm afraid.)
    The minilite rotor is listed on Ebay, along with the go kart 150 brake calipers and the master cylinder. I've included pictures of each
    Here's the additional pictures of the items on Ebay. Apparently, there's a limit of 5 pics per post.
    If you're interested and want more precise measurements, let me know.
    Oops! Double-posted.
    Thsnks alot for the info!
  1. 1/2 Scale Crawler in the UK
    By chrishunter5370 in forum Kid's Buggy Group
    Last Post: 07-05-2018, 06:34 PM
  2. 50% scale Shotgun II
    By spud nut in forum Rorty R16 Shotgun II Two Seater
    Last Post: 02-26-2017, 01:40 AM
  3. Mill scale :mad:
    By cdnjaguar in forum MiniBuggy.net Lounge!
    Last Post: 02-06-2015, 10:54 AM
  4. Scale - please help
    By Nuff_Said in forum The Drawing Room
    Last Post: 03-04-2010, 01:04 AM
  5. 1:3 Scale Ferrari 312PB
    By KWiKSand in forum MiniBuggy.net Lounge!
    Last Post: 12-02-2006, 04:01 PM
