Thread: roketa gk-32
Results 1 to 5 of 5
    roketa gk-32
    I have engine parts, trans parts and misc. Parts for sale
    Re: roketa gk-32
    May 2013
    Easton, PA
    Is this a trailing arm type rear suspension setup? if so, I'd be interested in the rear arms and hub assemblies.
    Re: roketa gk-32
    Just engine parts and trans
    Im using arms
    Sorry
    Re: roketa gk-32
    May 2013
    Easton, PA
    NP, you may move the engine/trans on pretty fast with an ad for it over at buggynews as well---quite often there's lots of roketa guys needing that trans.
    Re: roketa gk-32
    Jan 2009
    Los Angeles
    XBird, i'va had my eyes out for a Rear Trailing Arm and hubs also. I used the hold bearing housing and made new arms off of that so I could use the same hub and axle stub.
    They axle stub was a major pain in the ass to cut on my buddies industrial Lathe. It was a super Hardened steel that kept dulling the Lathe Cutter! You would think it would be cheaply steel that would cut like butter! It took me about 2.5 per each stub to cut it down so I could weld on the u-joint setup.
    I'll keep you posted if I see any arms and hubs for sale.
  1. Roketa LT conversion.
    By rgvkid in forum Projects in Progress
    Last Post: 01-29-2016, 10:47 PM
  2. roketa gk-31 ktr-1000
    By stingersx in forum MiniBuggy.net Lounge!
    Last Post: 05-21-2013, 10:05 AM
  3. Turbo Roketa build
    By motofool250r in forum Projects in Progress
    Last Post: 04-08-2013, 02:48 PM
  4. my roketa with a vfr700 2 motor
    By wellmantodd1 in forum Show off your toys in here!
    Last Post: 01-30-2013, 03:56 AM
  5. Suspension Video. Roketa LT conversion.
    By rgvkid in forum Show off your toys in here!
    Last Post: 01-31-2012, 09:52 PM
