Thread: Buggy fenders
Results 1 to 10 of 12
    Buggy fenders
    What is the best way to do this? Plastic or metal.
    Thanks
    Peter
    Re: Buggy fenders
    I've seen both, some guys cut down a plastic garbage can for fenders or you can hit up a trailer supply and get a metal fender (cut to fit) I think the trailer fender are a cheaper option. I guess it depends on where you source a garbage can.
    Re: Buggy fenders
    Quote Originally Posted by Lug-Nuts View Post
    LOL!
    You can always argue "They were in the trash area, I thought you were throwing them away!"
    Ever try to actually throw away a garbage can? They won't take them... I've had to cut them up and put them in the new can a couple of times.
    Tractor Supply may be a decent source for metal fenders.
    Re: Buggy fenders
    How about the plastic fenders from the newer beetles?
    Easy to cut and modify, lots of them in the junk yard.
    I guess it depends on your style of buggy.
    Re: Buggy fenders
    Thanks guys, my buggy is a upgraded ST4 and I looking into fender like the little ice cross karts have. This website looks like it has pretty good stuff. https://www.trailerpartsdepot.com/p-...5-flanged.aspx
    Re: Buggy fenders
    Dec 2015
    Near Pittsburgh, PA
    Tractor supply fenders are expensive here.
    I want to do the DS650 quad style...turn with the wheels.
    Re: Buggy fenders
    Do the CannedHam Spyder front fenders attach to the spindles?
    Re: Buggy fenders
    Dec 2015
    Near Pittsburgh, PA
    Looks like they do but they look heavy and expensive!
    You could make a pivot point on the a arm and then a mount to the spindle that would turn it...kind of what I am thinking.
    Or, you could mount directly to the spindle but mine doesn't look big enough...I guess it depends on how big the mounting arm is and the weight.
    Re: Buggy fenders
    Not expensive here, check the link. Obviuosly anything can be cut down to fit how you like. When I looked them they were big enough that one could be cut in half and now you have 2!
    http://www.etrailer.com/dept-pg-Trailer_Fenders.aspx
    Re: Buggy fenders
    Wow those are cheap. Thanks lug nuts
  1. Fl-250 fenders
    By Odyssey noob in forum Honda's Pilot & Odyssey
    Last Post: 01-10-2012, 07:21 PM
  2. Pilot Fenders
    By C-Dub in forum Honda's Pilot & Odyssey
    Last Post: 07-28-2010, 08:28 PM
  3. Pictures of new FL350 Front Fenders mounted
    By LiveWire in forum Honda's Pilot & Odyssey
    Last Post: 06-07-2010, 02:57 PM
  4. FL350 replacement fenders
    Last Post: 05-26-2010, 11:08 AM
  5. FL350 Fenders Released
    By AtvNut in forum Honda's Pilot & Odyssey
    Last Post: 02-15-2010, 10:41 AM
