So, per usual, as soon as I wake up I'm thinking about my dune buggy and things I need. One being a good notcher. So in reflecting mistakes I've made in the past and the problem of tube notchers not being able to make a steep cut in one pass I came up with an idea. What if you make two molds. One concave molds to hold the tube and another convex mold that is pressed into the tube at whatever angle needed to collapse the tube leaving you with a coped tube ready to be welded. There might be a need to cut the end of the pipe at a flush 45 in order to prevent overhang off the collapsed pipe at the end. No drills or hole saws would ever need replaced. All you'd need is different mold sizes. I plan on testing this out when I get home from New York but wanted to see what the community thought first.
Thread: Tube notching alternative idea..
Results 1 to 2 of 2
- Join Date
- Jul 2014
- Location
- Des Moines Iowa
- Posts
- 112
03-21-2016 11:00 AM
03-22-2016 03:23 PM
It could work, you would need to keep the two molds aligned rigidly to keep it from squashing off center, or having the tube shoot out.
You may run into problems with the effects of collapsing the tube right at the joint you are welding.
I would stick with a traditional notcher. I only used two hole saws for the entire frame, and i just ended up grinding the notch for the bonnet tube, which was too steep.Proud owner of a two seat pucker-mobile. Funco inspired mini buggy powered by a Busa. Giving out free rides to anyone brave enough.
CNC plasma tube notching w/ bendtech.
By JGSturbo in forum Shop TalkReplies: 554Last Post: 06-12-2016, 12:34 AM -
Tube Notching
By deaner in forum Shop TalkReplies: 5Last Post: 01-26-2014, 05:14 PM -
Simple and effective tube notching program
By tbwcurtis in forum FrameReplies: 0Last Post: 03-21-2012, 01:33 AM -
tube notching
By BONEDADDY in forum Shop TalkReplies: 8Last Post: 05-01-2009, 05:22 PM -
Tube notching templates
By standfast in forum MiniBuggy.net Lounge!Replies: 26Last Post: 09-17-2008, 08:09 AM
