Results 1 to 4 of 4
    Clutch master cylinder help
    So Im looking for the best option for a Hydralic clutch in my busa. I don't like the idea of a short throw pedal ( normal pedal with a stop). Nor the hand clutch. So I had an idea for using the rear master off a bike. There are some pedals without the masters that will work easily to mount it too. So would it push enough fluid to actuate the clutch or would it be to much also and I'd be right back to adding a stop on the pedal. I figured I could move the mounting position of the m/c until I found the sweet spot for movement and the. Use a heavy spring to give it a good feel. Or have i missed where they have the proper pedal for the job now. Please help thanks
    Re: Clutch master cylinder help
    I'm using the rear master cylinder off of a atv. I mounted the rod as low on the pedal as I could. This maximizes the travel. Only issue I have is the feel. It's really soft, but works well.
    Awesome. What kind of engine.
    Quote Originally Posted by slikrider View Post
    I'm running a 2006 CBR 1000. Works pretty good. running a 14t on the front and 66t on the back, really geared it down. Typically I cruise through the dunes in 3rd occasionally grabbing 4th.
  1. Jamar Master Cylinder help
    By Glamisman in forum Controls and electrical
    Last Post: 08-03-2012, 07:02 AM
  2. 1/2 Bore Master Cylinder
    By dirtrider in forum Controls and electrical
    Last Post: 10-25-2011, 10:42 AM
  3. Brake Master Cylinder
    Last Post: 10-02-2011, 07:45 PM
  4. VW Master Cylinder
    By zuverinb in forum Controls and electrical
    Last Post: 05-28-2011, 05:38 AM
  5. Clutch Master Cylinder
    By Baja Explorer in forum Controls and electrical
    Last Post: 09-07-2006, 10:46 PM
